CK25 HST push power problems…
   / CK25 HST push power problems…
BIG: does the tractor pull OK in reverse? If it is OK, then I would look into the FORWARD RV.
Your tractor uses 2 hi-pressure relief valves (4000psi), easily accessible. The FORWARD RV may have dirt in it, or a cracked spring. Easy enough to pull it and look.
If both forward and reverse are weak (low range), then you have a bigger systemic problem with the HST. I hope the fluid is clean, and the suction screen not gunked up.
You would not by chance know where both these RVs are located on my machine?
   / CK25 HST push power problems… #12
You should look at the thread I posted on TBN in 2010, dealing with the CK HST relief valves:
As for the HST charge pump, which is shared with the power steering pump, you can sometimes get an indication that that is the problem when the PS gets weak.
A proper approach to your problem is to get a service manual, a 10,000psi gauge, and test your pressures (HST fwd and rev, and charge).
2001 International 4700 Dump Truck, VIN # 1HTSCAAM51H379512 (A54865)
2001 International...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
BUYERS PREMIUM & PAYMENT TERMS (A56129)
BUYERS PREMIUM &...
2004 Sterling Acterra Cab and Chassis S/A Truck (A55852)
2004 Sterling...
2022 Ford Escape S AWD SUV (A55853)
2022 Ford Escape S...
S/N: 1240824 (A55853)
