CK25 Governor Springs
   / CK25 Governor Springs #1
DavPur
Newman Lake, WA
Kioti CK 25
Does anyone know how the two governor springs on a CK25 attach? They were accidently removed during a change of the Injector pump. The parts diagram describe them as springs 1 and 2.
   / CK25 Governor Springs #3
I've replaced them both quite awhile ago the same time I replaced my injector pump on a CK30. Check the old thread for pics. http://www.tractorbynet.com/forums/kioti-owning-operating/299077-ck30-running-rough-no-power.html
One spring fits inside of the other then I threaded a piece of light gauge wire through them both and through the holes in the block so as not to drop them down in there. Then using small lighted mirror and assorted wire picks I fabricated/bought managed to get it all hooked up. It was a battle...
Excellent reply Fuggley, just the info I needed, thank you! Also, thanks for the tips to prevent losing the springs deep in the bowels of the engine.
   / CK25 Governor Springs #5
Hey good luck with it. You need the dexterity of a heart surgeon but keep at it. I fabricated a flexible spring pick out of a light wire spring similar to these.
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
JOHN DEERE 7210R LOT NUMBER 263 (A53084)
JOHN DEERE 7210R...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
1992 Peterbilt 377 Sleeper Cab (A53472)
1992 Peterbilt 377...
23169 (A50324)
23169 (A50324)
