CK20s at 13 yrs old and 850 hrs
   / CK20s at 13 yrs old and 850 hrs #1
cldiver
2010 KIOTI ck20s
I haven't written anything here for 10 yrs. I still have my tractor and use it frequently. As the title says it now has 850 hrs. Since the problem with the front axle I have not had a single breakdown. It has spent its life outside in temps as low as -35 c and as high as 35 c. It has alway started and worked flawlessly. I let my son-in-law use it to repair his road..he is very hard on mechanical things. (electrician !!) and even he couldn't break it. If you want I can take some pics. It is looking like a 13 yr old tractor that lived in the woods but it still runs perfectly. I have used it to maintain a 1/2 km wood road, work with trees I've cut down, move rocks, load dirt in my truck, as a work platform and, tow truck.
Things wearing out...... loader pins will have to be changed out this year, tires (agri type) fronts done last year, rears probably this year. That's it. One thing that was not the tractors fault was that my fuel line and filter was freezing about 5 yrs ago. I asked some people about it and they told me to use a methanol type additive but the person said to add 1 litre. It dissolved the tank liner and clogged my filter. I haven't replaced the tank and still find black goo in the filter. I will change the fuel line this summer but it is 13 yrs old and the fuel additive probably weakened it.
This year I have noticed the power is down some and the hydraulics seem weaker (no leaks but pump probably getting worn). I adjusted the clutch 18 most ago.
I'm very proud of my little tractor. He's been a trustworthy and hard working team mate.
   / CK20s at 13 yrs old and 850 hrs #2
Reading of your long term experiences... I, Being a new Kioti owner, find your story encouraging…
Thanks for posting…
   / CK20s at 13 yrs old and 850 hrs #3
Glad your still making dust. :)
Like to old saying goes..."If you take good care of it,it well take care of you"
   / CK20s at 13 yrs old and 850 hrs #5
13 years and 850 hs? Just getting broken it! (y)
  • Good Post
Reactions: JJT
Here are some pics I took yesterday. I just finished replacing a bunch of grease fittings on the loader arms pins.
   / CK20s at 13 yrs old and 850 hrs #8
That sure is a solid little tractor.
   / CK20s at 13 yrs old and 850 hrs #9
Looks AT LEAST as good as a 13 year old Kubota in the same range, good going. When my TYM hits 13 years I will probably have 3000 hours on it at this going rate. I have had mine since June 2020 and I have 333h on it now.
It's been a great little tractor. It's lived outside since I bought it, mostly in the woods under a tarp when at my cabin. I've been surprised at the things I use it for....bulldozer, crane, tow truck, grader, portable scaffolding, and skidder. I'll probably die before it does...unfortunately my son in laws have no real mechanical knowledge and will probably destroy it treating it like an ATV. Maybe I'll sell it first.
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
Bush Hog R0-720 Pull-Behind Ripper Tractor Attachment (A51691)
Bush Hog R0-720...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
2010 Nissan Sentra Passenger Car (A51694)
2010 Nissan Sentra...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A51692)
2005 Toyota Tundra...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
