ck20hst
/ ck20hst #1
kioti20hst
ontario canada
Kioti ck20hst
since 2012 owner of a new ck20hst, loader, 60" finishing mower, 60" meteor blower, loaded R4's, 200h, no problems at all.:)
just wanted to say hi to everybody:)
/ ck20hst #2
:welcome::tractor:
/ ck20hst #3
good machine.
/ ck20hst #5
Hello fellow CK20 owner. Glad you are aboard, and let us know if you need anything.
/ ck20hst #7
Howdy!
Nice little tractor the CK20HST is.
/ ck20hst #8
Excellent first post! Same here! 110hrs later no problem, just a great tractor!
Waiting for snow...
Phil
/ ck20hst #9
good evening...
did that sound at all like alfred hitchcock?
/ ck20hst
yes may be....just found out what the " S " in ck20S stands for.......about 200h later....Sport!:laughing:
/ ck20hst #12
With so many great reviews about CK20HST , will anybody be interesting to upgrade for the new & improved 25hp ???
/ ck20hst #13
Funny I was thinking about finding a small turbocharger and adding it to my CK20HST, just for a little extra power. Much cheaper than a new tractor would be. And no it will not blow up the engine or overpower the hydraulics before that gets started.
/ ck20hst #14
A turbo will not increase a Diesel's HP unless it is integrated with the IP to increase the injected fuel to use the added air. If you do manage to increase the output power you may damage the engine unless it's designed to dissipate the additional heat. Bottom line is adding a turbo is not simple.
/ ck20hst #15
I have added turbo kits to the old Ford 7.3L diesels. After you bolt on the kit, the injector pump pressure is turned up to match the boost. I think a turbo could be added, if he ran 2-3 pounds of boost, without burning the pistons or valves. That would get him maybe 1-2 more HP. Having the manual transmission version, all things considered, I have not need the extra power to this point. I can't stop the wheels from turning in L1,2 or 3., and I have pulled a four foot brush cutter through small trees and high grass.
/ ck20hst #16
The Mercedes 617 Diesel engine (5 cylinder, 3 liter, iron head) started as a non-turbo (naturally aspirated=NA) engine. The subsequent turbo version had oil jets that sprayed the underside of the beefed-up pistons (for cooling). Also the altitude compensator on the NA injection pump was replaced by an ALDA that sensed boost pressure to increase the injected fuel with increased boost. The turbo IP is a different design as well. If you disconnect the turbo boost pressure from the ALDA the engine loses a LOT of power. The extra injected fuel is needed to spin the turbo to generate much boost. The max boost is only about 12 psi as I recall and you needed 2000 rpm to get any noticeable power increase. I know we're just talking here but just adding a turbo to a diesel won't do much except, maybe, damage the engine.
/ ck20hst #17
Could be the 'German precision engineered' pistons, etc. were a bit TOO finely engineered as there are 3 Kiotis and a couple of Montanas in this valley with add-on turbos that seem to be holding up pretty well :confused3:
/ ck20hst #18
With the 1992 Ford 7.3, you bolted on the kit, set the injector pump and rolled on down the road. My friend used it to do hot shot loads. He got over 300,000 miles on the engine before he sold it. Nothing was changed internally. You can take anything to the extreme, but if a turbo was add to the CK20s, it would produce much more torque with a modest HP increase. Most industrial diesel engines are built to withstand a turbo. An example would be the Yanmar diesel in the John Deere Gator. There are aftermarket kits that bolt on. Diesel Turbo Kit for the John Deere Gator HPX / XUV The Kioti engine is used on multiple applications just as the Yanmars are.
1970 Freehauf Lowboy, 20' Deck with 3' Dovetail (A62679)
1970 Freehauf...
2013 JOHN DEERE S550 GRAIN COMBINE (A64277)
2013 JOHN DEERE...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
3-Pt Disk (A66285)
3-Pt Disk (A66285)
2016 CATERPILLAR CT660 SBA 6X4 DUMP TRUCK (A63276)
2016 CATERPILLAR...
New 50Pc Equipment Key Set (A65579)
New 50Pc Equipment...
