CK20-Won't Start!
/ CK20-Won't Start! #1
aosbill
Massachusetts
Kioti
I have a CK-20 about five years old. Always cranked right up. Now when I put the key in the ignition and turn the ignition to any position, nothing happens. Replaced the battery, and the ignition switch and still nothing. Replaced the battery cable connectors as well when I replaced the battery. Cleaned the ground cable that attaches to the tractor. Reattached everything and still nothing. Any help would be appreciated as we are getting close to the SNOW season here in New England. Thanks in advance.
/ CK20-Won't Start! #2
Does anything come on? Dash lights, head lights, glow plugs, does the starter turn the engine over?
/ CK20-Won't Start! #3
Might post this msg in the Kioti section of this forum, lots of Kioti experience there. It's down below these general forums sort of in the middle.
Mike
/ CK20-Won't Start! #4
Time to get a test lamp and/or VOM.. and 'follow the volts' see where you have power and where you loose it.
might be a defectiver relay or something.
start at the battery and go from there.
soundguy
OUTBOARD ENGINE STANDS (A66738)
OUTBOARD ENGINE...
2018 Ford Focus (A61574)
2018 Ford Focus...
2025 CATERPILLAR 265 SKID STEER (A65056)
2025 CATERPILLAR...
2014 Infiniti QX60 SUV (A66738)
2014 Infiniti QX60...
2013 KENWORTH T370 DUMP TRUCK (A65054)
2013 KENWORTH T370...
2020 FREIGHTLINER M2 106 WATER TRUCK (A67714)
2020 FREIGHTLINER...
