CK20 Shifting/Gear Selection?
   / CK20 Shifting/Gear Selection? #1
Sandlot
CA. High Desert
Kioti CK20(Gear)
I have been moving a large pile of dirt left over from my new house project. I have 2 1/2 acres and I am moving it to the rear of the property, approx 275 feet. How should I handle the distance I must travel? I have been making the trip while loader is full in Hi/2nd gear. The return trip in Hi/3rd gear. I have tried to shift on the fly from second to third, but always get a bit of gear grind. So, I started just taking off in 3rd but need to slip the clutch more then I like, or lug the engine. Do you folks shift on the fly?
   / CK20 Shifting/Gear Selection? #2
Only 1st and reverse are synchronized on the CK20 gear transmission.
The specs on the tranny say "Synchro/Constent". Guess that dosen't mean what I thought! :p
   / CK20 Shifting/Gear Selection? #4
Yes, the Syncro part is First - Reverse.
Constant must mean "Put it Second and stay there"
You'll get used to it !
Jim
   / CK20 Shifting/Gear Selection? #5
Don't if it will work but you could always try double clutchin like we do in them big trucks.
Yea, that requires application of throttle between clutchin, and I am using the hand throttle. Guess I will live with the clutch slippen to get going in 3rd gear. ;)
   / CK20 Shifting/Gear Selection? #7
"Double clutchin' " only works on the CK20 if you hapen to be going down a slight slope! (not too safe) the tractor slows too quick before you can get the gears speed matched. Was only able to get mine (when I had the 20) to do it twice and that was no load and going down hill, other wise, find a "happy" gear and go.
550 gal Gravity Flow Fuel Tank with Stand (A50515)
550 gal Gravity...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
2011 Chevrolet Avalanche LTZ Crew Cab Pickup Truck (A50323)
2011 Chevrolet...
JOHN DEERE 6105D TRACTOR (A51243)
JOHN DEERE 6105D...
Ashland 5 yrd Dirt Scraper (A50515)
Ashland 5 yrd Dirt...
(10) 7 x 9 Treated Posts (A50515)
(10) 7 x 9 Treated...
