malk315
Hi all-
Since I needed 300 hour service (big one that is all fluids all filters, front axle inlcluded etc) and in the last month or so I've been starting up cold w/ 45 seconds plus tons of smoke clearly cylinders not firing.... I figured I let them take care of it. Here's what they did:
- All filters, HST oil
- Front axle
- Pulled and cleaned glow plugs
- New ignition switch (this turned out to be root cause of no glow)
- di-electric greased all plugs under lower panel (I had new harnesses installed couple years ago from corrosion)
- Cenimatic upgrade on joystick -- my machine bought in '06, mauafactured in '03
- New left flasher that was broken off
- grease everything etc.
When the glow wasn't working I still had the yellow light on the dash, you could hear the relay click when light lights up and click again when it goes out. Start was just tons of white smoke and she would take at least 45 seconds to 1 minute when down near freezing outside (but still in garage so moderate cold start).
Heading up there tomorrow to pick up the machine.
Next thing for me will be a new bucket edge (plan to have my brother weld on some new metal) and thinking about getting a rear blower from upper valley to do some business with them.
I'm very happy they opened a location in Swansea. I hope it remains sustainable for them -- I haven't run the machine yet, but from what it sounds on how they did everything I will be using them exclusively from now on.
I'm a victim of my local dealer Harvard power in Harvard, MA being dropped by Kioti -- now I'm back in good shape with a means to haul the machine and what appears to be top notch service and happy to take care of the machine even though it wasn't born at that dealership!
Here's some pictures of my towing setup from when I dropped it off last weekend -- by bro's '93 F350 dump truck with 460 V8 gas, 5 speed, PTO driven Iraqois dump body, diamond snow plow, pintle and receiver hitch setup w/ 7 way for trailer w/ electric brakes. I use it w/ my 16' trailer (~7000 lb gross) for hauling the CK20. The glare from the sun was terrible so I couldn't get a good picture -- this is the first haul of the machine w/ my bro's truck instead of my buddy's 2000 F250 which both pull it great.
It was tempting to just load up one of those shiny new CK35's they had sitting around and borrow that for the week
- Front axle
