CK20 redesign ?
/ CK20 redesign ? #21
I have noticed a marked improvement in the hill climbing ability of my CK20S in high as I have put more hours on it. The first time I used the tractor when I got it, I was a little worried as it seemed to struggle with a couple of small hills on my property, but as I have added hours, it seems like the engine has picked up some power and while it may bog slightly, it is not the problem that it was when new. I think I would prefer a 25-27hp engine in this tractor before adding the 3rd gear. Additional power might make the 2 speed trans more usable.
Of course add the 3rd speed and the power and it might be closer to perfect.:)
/ CK20 redesign ? #22
I recently bought a Kubota B7800. When looking at Kioti, I REALLY liked the CK20 - many things about it were excellent. For some reason the folks grumbling about the two-range transmission kept echoing in my mind.
The B7800 is a great tractor but considerably more bucks last time I looked.
As one of the grumblers about the lack of a three range HST on the CK20 and as a former CK20 owner, I need to put things in perspective: Given the choices on the market today in the same price range and considering Kubota's new B series, Mahindra and the CK20, I'd still choose the CK20 unless all I was planning to do was mow. The CK20 still has a considerably more powerful loader than the B series machines under 30hp.
I would rather live with a two speed hydro than a wimpy loader.
/ CK20 redesign ? #23
I feel I should clarify my thoughts, I think the ck20 really is an awesome brute and is a very capable machine and it is the size physically that I require for the jobs I do. It is a world above my old Kubota and well ahead of the similar speced Kubota's for less $$$,
but there are times I feel a little more power and another range would be nice but maybe Derek is correct
quote (I admit I have found a few things I could not do easily with my CK20HST but what it has done is amazing for it's size and power and if I needed more I would buy a larger tractor.
If everyone makes their smallest tractors bigger every year, the people who don't need the extra power and capacities will have to pay for more than they need. I like the CK20 just the way it is...)
But maybe Rick Wallace also is
quote(Well here is my thoughts...........
Get rid of the new CK27 pull that engine and put it in the CK20 and give us a new 3 range 24hp subcompact!)
So maybe the solution is to leave the ck20 the way it is and add a second model on that frame size with a little bigger motor and the extra gear for a few more $$$ but still cheaper than the similar and less capable Kubota's and Kioti would really have the best to offer everyone. Gary P.s. sorry about he long ramble.
/ CK20 redesign ? #24
Most if not all the other CUT manufactures are going with more HP in there CUT lines. There SCUT lines are now were the CK20 is at now. So should Kioti just drop the CK20 and go with the CK27 as the entry level? Just a thought.
KC
/ CK20 redesign ? #25
KC
Nope. The CK20 frame size is ideal for smallish acreage and that size is an important part of the market.
Once again, I think people need to interpret what is going on in this thread as constructive criticism and suggestions to improve the mightly CK20. I don't see any of the comments as suggesting it is a bad deal or non competitive, we are just suggesting a few changes that would make a great tractor even better.
And if Kioti ever did discontinue the CK20 I'd call up Rick and have him put one on layaway for me so I can have one once I'm finished with the work I need the DK40 to do.
/ CK20 redesign ? #26
Some of the question at least from me come from these comments:
http://www.tractorbynet.com/forums/kioti-buying-pricing/129495-lift-capacity-ck20-vs-ck30-2.html
Some have complained about power going up hills.
KC
/ CK20 redesign ? #27
KC
Absolutely. That is a relative weakness of the CK20 but its strengths greatly outweigh those weaknesses. The whole point about advocating for an upgrade to a 3 speed HST is to fix that issue. In the mean time, I managed to get my work done, just in low gear which made the going slower than it would have been if I'd had a mid range to choose.
/ CK20 redesign ? #28
I am not knocking the CK20 but I have one option on a purchase. I have had a Large Garden tractor with 2 ranges. I worked in low 90% of the time. How does the CK20 work in low range? Any hill issues?
KC
/ CK20 redesign ? #29
We have plenty of slopes and hills at our dealership. Feel free to test drive the CK20S on all the inclines and hills we have and see if you like the way it performs. You can also try out the loader on a pile of dirt and dig way.
The upgrade on the CK20S to 22hp and the gearing changes have helped a lot.
/ CK20 redesign ? #30
KC
No issues in low. It is a brute for its size in low. I like the fact that it is heavy enough that in low it rarely spins its wheels, especially in 4wd.
My issue with the earlier 2004 version was only related to the fact that there were jobs like mowing up an incline that I would have done faster if there had been a middle range. Low was too slow but plenty powerful. High was just geared a bit too high to go up a modest incline for a tractor that was also running a bush hog or burdened by the weight of a backhoe.
Michigan Iron says that there have been gearing changes even with the 2 speed. Maybe that helps. I doubt that one extra horsepower would do much however.
/ CK20 redesign ? #31
KC
Horsepower is where the marketing departments focus there advertising dollars because they know the general public obsesses about horsepower. Diesel engines develop much more torque than gasoline engines. My first diesel tractor only had 17 horsepower and I was always amazed at the work I could do with it.
Don
/ CK20 redesign ? #32
KC
KC
while i admit that i would love a mid range as well, the ck20hst is a brute in low range. my property is on the side of a small mountain in NH and my driveway is gravel and over 800' long with some pretty good slope. in high range i can't climb my driveway with just the tractor..... in low range i grade (pulling a 5' rear blade digging into the gravel) the driveway uphill (to pull all the material back up that washes out in heavy rain...) no problems.... i can also climb the driveway with a full bucket of material and with BH on at the same time (basically adding over 2,000lbs between the two)... no problems.... i guess that's where the issue arises.... there is such a difference in power drop off from high to low, that a happy medium for "working" transport would really make the ck20 that much better...
i have just turned 300 hours on mine and just love it.... you will not go wrong... by the way the low range still moves at about 5-6mph anyway.... just gives you more seat time....
good luck
/ CK20 redesign ? #33
KC
good luck
The snowblower is PTO powered? How does it do going up hill working.
KC
/ CK20 redesign ? #34
KC
No problems with the blower.... with my terrain, i did invest in vbar chains for the rear.... now its a tank in the winter... even when the driveway gets icy due to the snow melting and refreezing... i can blow snow going down and up the driveway...everyone told me that a 54" blower would be too much for the lower hp pto (i think it's rated at 16 or 17), but again the machine handles it well... now i wish i had gone to a 60" blower... i usually run the blower at about 2200rpm, with plenty of hp too spare...sorry, but i can't figure out how to add photos (i used to be able to add them to this forum), otherwise i'd show you my set up...jim
/ CK20 redesign ? #35
Thanks for the info KC
/ CK20 redesign ? #36
I have a 60" rear blower on my CK20HST too. My driveway certainly is not flat and I run the snowblower up hill without problems. I have thought about chains but have not found a need for them yet, with the loaded tires and extra weight of the cab it never had a problem with traction. I am also going in reverse and the tread of the tires (industrial - R4?) is designed for more traction rolling in reverse than forward. As far as the blower, you can see the driveshaft that runs from the rear PTO to the chaincase on the snowblower. It is a very simple setup and works very well.
I am sure everyone has seen my setup before but here are a couple of pics: (click images for larger view)
/ CK20 redesign ? #37
... The CK20 frame size is ideal for smallish acreage and that size is an important part of the market. ...
I'm with IT. I looked hard at the Kubota BX-23, as well as JD, NH and others. The CK20HST (very glad I got the HST) was the largest tractor I could fit in the garage and through narrow places around my property, and the smallest that could lift half a ton in front and bust out a ton in back with that easy-detach BH. As they say in Old Blighty, it's horses for courses. For my 2+ acres of heavy landscaping work, it's been just right. A mid-range gearing and faster hydros (mainly for FEL movement) would be nice. But as far as power goes, I rarely run the thing over 2400RPM, which is probably 70% power or so. (Anybody know?) And force is usually limited by release valves anyway, not engine power. I assume that a complete hydraulic redesign for higher pressure would be needed if they raised feed power, and that would have to boost the price some.
Well-balanced machine all around, IMO.
-Chelydra
/ CK20 redesign ? #38
To me, the solution is very clear. Own more than 1 tractor!!!:D:D:D
Seriously, one size fits all really means it fits nobody. We need biggger and smaller options for sure.
If I had the $, I would love to have a CK 20 also.
/ CK20 redesign ? #39
-Chelydra
Agreed. It would greatly benefit from a three range HST which I have to believe the folks at Kioti are going to add one of these days. That two speed is the only real weakness on the CK20 and now that Kubota has abandoned the 2 speed units I gotta believe Kioti will follow suit.
Add the 3 range HST and to the new quick attach FEL mount and you've got an even stronger argument that the CK20 is the ultimate 5 acre machine.
6 1/4 INCH OD 90 DEGREE ELBOWS (A63569)
6 1/4 INCH OD 90...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63276)
KNOW BEFORE YOU...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
PORTER CABLE AIR COMPRESSOR (A63569)
PORTER CABLE AIR...
