CK20 & Post Driver
/ CK20 & Post Driver #2
I would take this as a no. /forums/images/graemlins/grin.gif
/ CK20 & Post Driver #3
My dealer sells KingHitter Post Drivers and says you need a minimum of a 40HP tractor to operate it. I suspect the CK20 is too small for Post Drivers.
You have my permission to go and buy a bigger tractor.
/forums/images/graemlins/wink.gif
/ CK20 & Post Driver #4
What type of posts are you trying to drive?
You can use your FEL to push metal "T" posts into the ground, even in clay soils (easier when the soil is a little moist).
If you are talking about wooden posts, then for small tractors I think you are limited to a PHD on the rear end. The only wooden post drivers I've seen are big units designed for larger tractors.
I was just wondering if anyone has done this or not with the CK20. Most of the Post Drivers have more to do with GPM in Hydraulic pressure then Engine HP I thought. I was originally thinking about going with the Shaver HD8. The ratings stated that if you were above 5GPM for the tractor pressure you were ok. Since the CK20 has a 7 GPM, hence the reason I posted the question.
Link to show GPM requirements:
http://www.solexcorp.com/productfiles/shaver/postdriver.html
In any regards I have decided not to go with the driver and stick with the digger/auger style. The posts I intend to put into the ground 7'ft 6" half round posts.
/ CK20 & Post Driver #6
Here's my PHD set-up. Gerard
/ CK20 & Post Driver #7
One more view. It works great. Gerard
Thanks for the pictures GerardC! you'v got all the toys eh I mean professional grade equipment
/ CK20 & Post Driver #9
</font><font color="blue" class="small">( Most of the Post Drivers have more to do with GPM in Hydraulic pressure then Engine HP I thought. )</font>
You are right, the drivers require a certain GPM to work well. The other consideration is "who's in charge?". It will take a 40 hp tractor to have enough weight to prevent it from being thrown around by the post driver.
/ CK20 & Post Driver #11
Gerald
What brand is your post hole digger? It looks like a perfect fit for the CK20. I have very rocky ground so I'm a little leery about investing in the PHD if there is any hint at marginal performance.
On the other hand if I sharpened it up real good it could make drilling holes for ice fishing mighty quick. /forums/images/graemlins/laugh.gif Maybe next winter /forums/images/graemlins/grin.gif
/ CK20 & Post Driver #12
</font><font color="blue" class="small">( I like your building, and I bet the CK20's favorite channel on the big screen is RFD TV. /forums/images/graemlins/grin.gif )</font>
Thanks, but I like to call it my dog house. We all end up in one at one time or another! /forums/images/graemlins/grin.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/wink.gif Gerard
/ CK20 & Post Driver #13
My PHD is a GREENLINE MFG. FM5500 with 9" auger. Works great. The CK20 handles it with ease. Gerard
2020 FREIGHTLINER M2 106 WATER TRUCK (A67714)
2020 FREIGHTLINER...
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
GAS CYLINDER TRANSPORT BED (A67714)
GAS CYLINDER...
2015 CHEVROLET CAPRICE (A66091)
2015 CHEVROLET...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
2022 BOBCAT T870 SKID STEER (A65056)
2022 BOBCAT T870...
