CK20 Notes
   / CK20 Notes #1
CBB
Just north of the PA line in NY
JD 5320N Vineyard, 1981 Deere 910, 1980 Kubota B22, 1983 Ford 1710
The tractor is responding admirably to the workload. I have some pictures I will add shortly of some projects.
a. I am amazed at how quickly the screen becomes filled up when mowing with those little cotton like weeds. I have made a point to keep the screen clear on advice from TBN Kioti.
b. I had to disconnect the heater for the summer...to much residual heat even with the fan off. Someday I will install the heater so it has a cutoff valve for easier on/off. As it is, I had to disconnect the hoses and re-connect without running through the heater. Anyone installing a heater may want to make sure a valve is installed.
I am so pleased with this unit and would recommend it to anyone.
CBB
   / CK20 Notes
CBB
   / CK20 Notes #3
Having the same setup as you, I am curious as to where this residual heat is coming from. I know the pipes get pretty warm going into and out of the heater box, but there is no heat coming from the heater box. Did un-hooking the pipes work ? and how did you hook them together. Pics ?
   / CK20 Notes #4
   / CK20 Notes #5
Do you guys not have AC?
   / CK20 Notes #6
   / CK20 Notes
</font><font color="blue" class="small">( Do you guys not have AC? )</font>
AC Available Here
I don't have it but could buy it at the link listed above.
   / CK20 Notes
AC Available Here
   / CK20 Notes
</font><font color="blue" class="small">( Having the same setup as you, I am curious as to where this residual heat is coming from. I know the pipes get pretty warm going into and out of the heater box, but there is no heat coming from the heater box. Did un-hooking the pipes work ? and how did you hook them together. Pics ? )</font>
Pic attached of heater
   / CK20 Notes
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
Quick Attach Pallet Forks (A47384)
Quick Attach...
2003 FREIGHTLINER CLASSIC XL  SLEEPER (A52141)
2003 FREIGHTLINER...
1995 CHEVROLET P30 MOTORHOME (A51243)
1995 CHEVROLET P30...
2006 Reelmaster Toro 3100D Mower (A50322)
2006 Reelmaster...
Bef-Co Finish Mower - INOPERABLE/PARTS ONLY (A52128)
Bef-Co Finish...
