Buying Advice CK20??? Is it right for me???
   / CK20??? Is it right for me??? #21
I have a CK30 gear and have found that by using the low or high range I can get the exact speed for every thing I do. If I am out in the open it is high range but when I am on a steep hill or in in thick woods it is low. with 8 total speeds just about any speed can be obtained and is constant. The shuttle shift makes things that much better. I would think the CK20 would work the same as mine.
   / CK20??? Is it right for me??? #22
I have a CK20HST. It'll do what your looking for. I'm on just over 5.5 acres as well. About an even split between open and wooded land - mostly flat. A larger tractor would actually be harder to maneuver in some areas.
The R4s will chew the lawn a bit in 4wd. Not as much as when I start moving with my boxblade still down though(!).
I'd avoid the MMM. Get one for your 3-point. I suspect detaching a mmm would get old fast. In fact, I didn't even thing one was available for the CK20.
The first tractor I learned to drive was a JD 1948 Model A so I'm no stranger to pedals and shifters and gears and . . . I still like my HST.
It's a stout little machine.
Good luck and have fun!
   / CK20??? Is it right for me??? #23
That happened to me, went to the other K store and wanted to try it out. Salesman said "we don't like to get them dirty".
Went to Dick Batchelder and he pointed me to a pile of dirt and said "Have at it".
Exact same experience I had... I was only allowed to drive a Kubota around the parking lot, but Batchelder let me scoop dirt AND make a mess of their pallets with some forks.
Cummins Engine (A59230)
Cummins Engine...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2015 Toro Sand Pro 5040 Bunker Rake (A59228)
2015 Toro Sand Pro...
New Holland 308 Manure Spreader (A59814)
New Holland 308...
iDrive TDS-2010H...
2008 Freightliner B2 School Bus (A59230)
2008 Freightliner...
