Buying Advice CK20??? Is it right for me???
   / CK20??? Is it right for me??? #1
jwrambo
First, I am new to the forum, and I am thanking everyone in advance for your help in making a buying decision. I have just purchased five acres in the NE Georgia mountains. It is a mix of about 3.5 acres of cleared pasture that slopes up to 1.5 acres of wooded area. The pasture area consists of fescue and a mix of weeds, clover, etc. It is not the smoothest, and pretty bumpy when driving the truck or utv around the property. It is however relatively flat. It transitions into a slope going up to the wooded area. It rises about 3' every 10'. Through grading, I plan to lessen the steepness of the slope to make mowing easier. The wooded area is loaded with poison ivy and other undergrowth. Hopefully, I have described the property well enough to facilitate ya'll giving me informed advice. I really like the CK 20 even though it is a little more $ than the Massey Ferguson GC2600. Both of them have free loaders right now. Work wise, I will be mowing the pasture area, clearing brush in the wooded area, moving firewood, maintaining a gravel road, tilling and maintaining a garden, the occasional snow removal, and other small farm chores. Construction wise, I will be building a couple of pole barns, so an auger will be necessary, doing the site work for the barns, landscaping around the house and property, and doing some final grade work. Seems like used units in great shape are hard to come by, and with the free loader offer the difference between new and used is very small. Spec wise it seems as thought the CK20 is superior to all the other brands with the exception of a little less horsepower. That is the only spec on the CK20 that concerns me. I think I like the added weight of the CK20, and feel as though the weight will help with traction. On the other hand, is 22 hp enough for the 2,200 pound weight of the tractor? Will the CK20 handle the tasks above? What type of mower would be best for my situation? The Kioti dealer is telling me the MMM is a pain to remove. Is he doing this cause his unit does not have the mid PTO? Would a finish mower or a bush hog serve me better? What size mower/bush hog decks can I use? My head is spinning, and since I do not have any tractor experience I am leaning heavily on the opinions of others. Thank you so much in advance for everyone's help. Jason
   / CK20??? Is it right for me??? #2
You are looking at two different categories of tractors. The CK 20 is a compact tractor.
The GC 2600 is a sub-compact tractor, It is quite a bit lighter than the Kioti.
Either should be able to do what you want to do. I would go with a 3 point mower.
   / CK20??? Is it right for me??? #3
Read as many posts as you can about the CK20. There is plenty of information in threads already here to tell you the pros of cons of that tractor. It is way more tractor than the GC2600. It will do everything you want. I'd go with a rear finish mower and a small bush hog or flail. Or if you really want a MMM, look at the Bobcat version.
I'd easily pick the CK20 over the MF GC's. The only similar tractor to the CK20 is the TYM T233. In the TYM, you can get about the same frame size/dimensions. On the TYM frame, if able to swing a few more dollars, (maybe, maybe not), you can step up the HP to the T293. Same chassis, but 29 HP. Smallest frame with maximum HP I've found
Of course, John Deere and Kubota have nice machines in this size range (2000 series and B-series). But, they'll cost you thousands more.
For the money, the CK20 or BC equivalent are virtually impossible to beat. A new player is LS. I think they have a comparable model for similar money too.
Kraftykeltic, the MF is definitely lighter. I mentioned it because it is in the same price range. I have been told the MF will loose traction before it runs out of power. I have also been told the opposite about the CK20. I was told it could run out of power before it would loose traction. Guess it also depends on HST vs. Gear. I am open to either. What exactly is a three point mower. I am new to all of this. Again, I thank you.
Gittyup, what is the TYM? I cannot figure out the acronym. JD is just too much, and Kubota just seems inferior in every spec. Even the MF specs out better than the Kubota. I have been reading as many posts as I can to learn as much as I can. On some of the posts, I have read concerns about the engine stalling going up inclines with the HST. I have also read complaints about the speeds with the manual. What would the pros and cons be? So you do not think I would have any problems with the jobs listed above, or am I asking too much from a small unit?
I also was wondering if I am going to create ruts in my future lawn with the R4 tires? This may be the only time a lighter weight unit would be advantageous, thoughts?
   / CK20??? Is it right for me??? #6
TYM is a manufacturer of a competing tractor. Yes the CK20 will do all your chores quite effectively. But, IMHO mowing is it's weakest chore. Still plenty capable with a 5' finish mower, or a 4' bush hog.
   / CK20??? Is it right for me??? #7
Here is a little info. A 3pt mower is a mower that fits on the 3 point hitch on the back of the tractor. This can be a finish mower, think sharp fixed blade like a lawn mower or it can be a rough cut mower, sometimes called a rotary cutter, bush hog brush hog, etc. The finish mower will give a great looking cut in grass, but not meant for brush or saplings. The rotary cutter has dull swinging blades. and is best for rough stuff, and will survive hitting rocks, and big stumps. etc. There is also another kind called a Flail, that has multiple "knives" that is kind of in between, gives a good cut but will survive some rocks, and is considered safer. (doesnt throw rocks). In my opinion buy as much tractor as you can afford, A lot of people start with a smaller tractor and trade up, as a larger tractor seems intimidation to them at first. Now as to Hydrostat vs. gear, well I fall into the Hydro lover camp. as I really enjoy using them for loader work and mowing with my rotary cutter. The control of the tractor is just so much better in my opinion. I used gear tractors for many years, but will never go back. The only thing I can think of that gear tractors do better is plowing a field. Of course this is a big controversy on this forum, and you will get a lot of opinions, but I think about how happy I am with the hydro every time I use the tractor. Good luck in what ever you choose.
James K0UA
   / CK20??? Is it right for me??? #8
Also another controversial issue, and a lot of opinions here. The R4 tires are a compromise tire. No one tire does everything well. I have the R4 tires and like them. They are pretty easy on the lawn, but not as good as R3 (Turf) tires. R1 (Ag) tires are the worst on the lawn, but the best traction in mud. R4 are the best for load carrrying ability in loader work, and are the toughest as far a puncture resistance. Not that great in mud, maybe better than R3, but not as good as R1. Of course chains can be put on all types to improve traction in all cases. Yes a lighter tractor will in general put less pressure on a lawn. Of course the wider tires, like R4 and R3 usually are, will also put less pressure on the lawn. Keep asking questions, we will keep trying to answer them.
James K0UA
   / CK20??? Is it right for me??? #9
As a dealer (Kioti) and and being around tractors all my life, I would at minimum recommend the CK20. It is definitely more tractor than the sub-compacts (GC's, BX's and 2305's). More tractor weight, larger frame, more loader capacity, larger tires and a standard cat. 1 3pt. hitch. On subs, you would have to use "low profile" implements to get them to lift high.
Most of what has been said is correct. The hydro is the way to go, however, don't expect to climb moderate slopes in high range. That's what low range is for, on any tractor. It's not a fault of the tractor.
Kioti does not make a mid-mount mower yet, have been hounding them for a while but their focus now is for a new "sub" for next year w/ a MMM on it.
My only concern is that even w/ the CK20, in time you may wish you went a little bigger, possibly a CK27. W/ the the 20, you can only really use 4' implements, 5' finish mower and a 27 or larger can take 5' implements and 6' finish. Definitely go w/ the R-4's.
The 20 is an excellent tractor as really all Kioti's are. They are kind of the "diamond in the ruff" so to speak.
k0ua, I woke up this morning feeling mildly retarded when I realized when I asked about a three hitch mower, it was just one that hooks up to the three point hitch. Wish I could have retracted that one. I'm thinking I could use a finish mower since I plan to use a rock rake to make sure the pasture is clear of anything that could damage the blades. Thanks for the advice on the tires.
Tractortidy, when talking about a larger tractor, will it do a better job, or just do it faster since it can use larger implements? The reason I ask is I like the smaller size to be able to work in my wooded area, and if it takes me just a little longer to till my garden because I had to use a 4' tiller that isn't the end of the world. A bigger mower would be nice, but I think 5' would get it done pretty quick. Have read on the various forums the hydro does stall going up an incline, correct? Have also heard complaints about the geared tranny being too slow in 2 and too fast in 3rd. What is your experience on that? I would like a hydro, but I found a dealer with a geared unit at the old price that is awful attractive.
2021 VOLVO A40G (A52472)
2021 VOLVO A40G...
378807 (A51572)
378807 (A51572)
2007 WABASH 53FT DRY VAN TRAILER (A52576)
2007 WABASH 53FT...
2018 POLARIS RANGER 570 EFI UTV (A51247)
2018 POLARIS...
2018 CATERPILLAR 259D SKID STEER (A51246)
2018 CATERPILLAR...
