CK20 HST making knocking noise and blowing blue smoke
   / CK20 HST making knocking noise and blowing blue smoke #11
My fuel filter has the fitting in the bottom...NAPA brand. I have seen Racor filter units with them too.If no drain, you can remove the filter, and invert it, drain the water,then you must refill to the top or prime to restart..Fuel collects water, it does not burn well. A Racor filter element will not let water past it>. Jy
Hi Again,
Dealer has finally looked at the little machine and has said that it was a valve and not an injector... bummer, I guess it could have been worse. Is doing a valve at this amount of hours normal 600 hours max...;
   / CK20 HST making knocking noise and blowing blue smoke #13
"Is doing a valve at this amount of hours normal 600 hours max...;"
Hmmm..be interesting what cause this.
   / CK20 HST making knocking noise and blowing blue smoke #14
Normally, we do not see valve or injector or engine rebuild issues until around 5000-7000 hrs use. This valve issue is premature by a long ways. Ken Sweet
   / CK20 HST making knocking noise and blowing blue smoke #15
Hopefully it didn't drop the valve and take out the piston.
   / CK20 HST making knocking noise and blowing blue smoke #16
Valve issues at 700 hours are way pre-mature.
   / CK20 HST making knocking noise and blowing blue smoke #17
Mine was about 100hrs, fixed under warranty. Ran better after the fix than it ever had, so probably a defect from the start.
2000 Sterling L9513 Winch Truck (A56435)
2000 Sterling...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
Toyota LPG 7FGCU20 3,400 Lb. Forklift, S/N 86163, Dual Mast, Tilt, 19,871 Hours Indicated, Asset#... (A59076)
Toyota LPG 7FGCU20...
2011 JACK COUNTY 130BBL VAC TRAILER (A58214)
2011 JACK COUNTY...
LOT: Steel Work Table 36" x 72" w/8" Craftsman Grinder, (2) Lockers (VISE NOT INCLUDED) (A59076)
LOT: Steel Work...
