CK20 HST Losing Power
   / CK20 HST Losing Power #1
mono
My CK20 HST has recently been giving me trouble. Has been running like a champ, but now it is intermittently losing power.
It will start up no problem, and run strong for a bit, but then act like I am pulling the throttle way down. Wait a bit, then it will run strong again. Then loses rpm's?
Any ideas?
   / CK20 HST Losing Power #2
I would start with the fuel filter. How cold has it been in your area? Diesel will wax up when real cold. As a desert rat, I couldn't tell you how cold it needs to be for this to happen, but there are additives that could help. But my first guess is a clogged filter.
   / CK20 HST Losing Power #3
Sandlot is spot on. Your description sounds just like a clogged fuel filter.
   / CK20 HST Losing Power #4
I agree with the other 2. Desiels loose power when the filter is clogged unlike a gas that will just choke off. If that doesnt solve it then you may have some clogged injectors.
   / CK20 HST Losing Power #5
Let us know after you change fuel filter and check air filter how it goes.
Fuel filter did the trick guys. Thanks for your help.
New Wolverine Skidloader Sickle Bar Mower (A50774)
New Wolverine...
2017 E-Z Beever M12R Towable Brush Chipper (A51691)
2017 E-Z Beever...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
2015 F-550 Bucket Truck. (A52748)
2015 F-550 Bucket...
2020 Kubota BX2380 (A50120)
2020 Kubota BX2380...
