CK20 HST Losing Power
   / CK20 HST Losing Power #1
mono
My CK20 HST has recently been giving me trouble. Has been running like a champ, but now it is intermittently losing power.
It will start up no problem, and run strong for a bit, but then act like I am pulling the throttle way down. Wait a bit, then it will run strong again. Then loses rpm's?
Any ideas?
   / CK20 HST Losing Power #2
I would start with the fuel filter. How cold has it been in your area? Diesel will wax up when real cold. As a desert rat, I couldn't tell you how cold it needs to be for this to happen, but there are additives that could help. But my first guess is a clogged filter.
   / CK20 HST Losing Power #3
Sandlot is spot on. Your description sounds just like a clogged fuel filter.
   / CK20 HST Losing Power #4
I agree with the other 2. Desiels loose power when the filter is clogged unlike a gas that will just choke off. If that doesnt solve it then you may have some clogged injectors.
   / CK20 HST Losing Power #5
Let us know after you change fuel filter and check air filter how it goes.
Fuel filter did the trick guys. Thanks for your help.
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
(250) Safety Traffic Cones (A50121)
(250) Safety...
John Deere Z994R (A50121)
John Deere Z994R...
2002 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2002 Ford F-150...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
