Ck20 HST leak
   / Ck20 HST leak #1
buckboard
Hey guys
I have a ck20hst that has developed a leak at the plug in the transmission
The plug releases soem hydraulic fluid every time I press on the back up pedal
this plug is located on the right side of the tractor inside the centre frame
I have tried several times to tighten it with an 8mm allen key but it seems to continue to leak
Not haveing a parts breakdown I am afraid to take the plug out completely as I do not know what is in behind this
The unit has 450hours and I changed the Hydraulic fliud last fall with no problems until this past week
Any suggestions on how to get this sealed
   / Ck20 HST leak #2
Hi, assuming this is a Kioti CK20, I suggest posting this in the Kioti owning/operating forum. There are several dealers there who can help you. If you are near Penn... then come to the Picnic on Saturday, June 7, and you can discuss it with the mechanics there.
   / Ck20 HST leak
Thank you
I will post on Kioti forum.
i am in Ontario .... may be a fair drive to the picnic but thanks
Flat bed utility truck with inline 6Cy engine (A55301)
Flat bed utility...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2017 MORBARK BEEVER M12RX PORTABLE WOOD CHIPPER (A54756)
2017 MORBARK...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
1990 John Deere 2955 Cab Tractor (A55218)
1990 John Deere...
