CK20 - greasing front axle pivot
/ CK20 - greasing front axle pivot #1
Slackdaddy
Land of the Free
Kioti CK20HST
The front "pivot block" will not take grease, just a 1/2 pump and it's not taking anymore, pulled the zerk, it's fine.
I have the front up and tires off (50 hour), after trying to grease it, the axle will not pivot easily, so the grease is putting presure somehow.
Should the grease flow out around the pivot shaft ??
Thanks,,
Slack
Anyone with a CK20,, does the grease come out around the front axle pivot shaft when pumping the front zerk??
Hate to bump it, but trying to get this thing back to gether.
Nick
/ CK20 - greasing front axle pivot #3
I have the same problem from time to time. Sometime it takes grease, and sometimes it won't. Now that I have over a 100 hrs on it, she takes grease most of the time. I lift the front end up with the loader and push the axle around if the gun won't release due to trapped pressure and once it releases, I can give her a few more pumps. The grease will come out around the pivot.
/ CK20 - greasing front axle pivot #4
I have the same issue with my 3054xs, but as Sandlot stated, if you swing the axle through its' range of motion it will take the grease; just not easily. Thankfuly, it's only every 50 hrs, or so
/ CK20 - greasing front axle pivot #5
It has always been difficult for me also .
480 hours....i tried a few weeks ago and could not pump more than half a pump like Slackdaddy
/ CK20 - greasing front axle pivot #6
This was brought up a few times with the CK30s. My CK30hst is the same way. Sometimes takes a little and sometimes doesn't. Lifting up the wheels and working the axle back and forth helps at times and no, the grease shouldn't be coming out around the pivot shaft unless it's worn out. Michigan Iron and Equipment, dealer on this forum, had posted that it's all a tight fit and this is normal. Only when the pivot bushing starts to wear will it take grease easily. Sorry, I couldn't find the previous posts a few months ago.
2014 VOLVO A40G WATER TRUCK (A62129)
2014 VOLVO A40G...
2021 Gatormade Lowboy Trailer (A62613)
2021 Gatormade...
(1) KUBOTA 8 LUG RIM (A64280)
(1) KUBOTA 8 LUG...
Coats 1550 3D Wheel Balancer Machine (A61573)
Coats 1550 3D...
66in Bucket Skid Steer Attachment (A61572)
66in Bucket Skid...
2012 Gastron 18ft Boat w 18ft S/A Boat Trailer. (A61574)
2012 Gastron 18ft...
