CK20 going away?
/ CK20 going away? #1
KenGod
PA
CK2610HST
My dealer picked up my CK20 today to get a backhoe on it and the driver told me that the rumor mill has it that the CK20 is going to be a new subcompact they are making, no more CK20 in the compact series, Only CK25 and up in the near future.
Anyone else hear of This?
If so will that do anything to the future trade in value of the CK20?
/ CK20 going away? #2
Rumors....
I heard Kioti was going to buy K*bota.
Call themselves KIOTABOOTY
As far as I know it's a rumor, I wouldn't mind it though.
Put a CK25 motor in a CK20 Chassis Call it the CK25 LBA
Then shave a bunch of weight from the original 20 etc etc
Hmmmm How do you turn a CK20 into a subcompact......
Limit it's 3pt hitch width....
Cut the loader lift Cap in half....
Make bucket smaller.....
Remove 800lbs of cast iron....
Add plastic....and Aluminum....
Cut it's ground clearance in 1/2.....
Only offer it in an HST Model....
Make Remotes NON-Available....
Shrink the backhoe available for it....
Make the only Hoe buckets avail a 12" and 16".......
BTI
/ CK20 going away? #3
I kinda doubt that Kioti would ditch the CK20. They sell a lot of them and have just phased out it's predecesor the LB1914.
I wouldn't mind however if they stuck a 25hp engine in the CK20. That would be just about the only thing I'd do other than also give it a 3 range HST. Then they could drop the CK25 :D .
/ CK20 going away? #4
I wish they would have come out with the CK20 with the 25HP this year. i would have bought one. The weight of the 20 frame would be an awesome combo with the 25hp engine.
Cork
/ CK20 going away? #5
I would agree with droppin the CK 25 ONLY if they lower the price on the 30.
BTI
/ CK20 going away? #6
I agree with that!
/ CK20 going away? #7
Here's "my" thoughts, since they have now upgraded the engine in the DK35 and used the old DK35 engine in the CK35, this all but eliminates the need for the CK25/30. The engine out of the CK25/30 will be dropped into the CK20 (new CK20+) and they can eliminate the CK25/30 and will have fewer model's to have to deal with and one in each HP range. Make sense?
Steve
/ CK20 going away? #8
I have a great idea......
Since we are doing all this swapping around lets just put the 35hp engine in the CK20 and make a small medium and big framed model
The CK35 SFM (former CK20)
The CK35 MFM (former CK35)
The CK35 BFMF (former DK35)
<WEG>
Cut down on costs etc.......
Why don't they listen to me LOL
BTI
/ CK20 going away? #9
I like the idea of the 25hp in the CK20 chassis, and keep the ck20. That way you have 2 hp options in both chassis. I may have gone for the smaller chassis with the 25hp motor, but I really like my ck35.
/ CK20 going away? #10
That is what Kubota does with the B7510 and B7610 and also what JD does too with the same size machines.
BTI just wants to pop wheelies with his 35hp CK ex-20.:eek:
/ CK20 going away? #11
(If I win the Lottery) I am just the type who would want to get the 35 hp engine and put it in my CK30HST...or maybe just turbocharge the 30??
It appears from specs the 35 HP bore is 4 mm larger, stroke is the same and cooling system capacity is .2 liters more
Some may argue this is totally unnecessary... (la la la la la I can't hear you!)
I wonder if they did anything to the HST or whatnot besides installing the bigger bore engine?
Back to reality---it works just fine as is, unless you intend to go uphill in high, full pedal.
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Westerns 8.5 Pro Plus w/Quad, Ultra Mount 2 (A62679)
Westerns 8.5 Pro...
1987 Kenworth T800 Day Cab (A62613)
1987 Kenworth T800...
72in. Land Plane (A65640)
72in. Land Plane...
7888SFL (A61567)
7888SFL (A61567)
2022 CAT 289D3 Skid Steer (A62613)
2022 CAT 289D3...
