Oil & Fuel ck20 fuel use
/ ck20 fuel use #1
mpham
North/central Massachusetts
Kubota B 2650 cab
I have 8 hours of moving fire wood, digging a few rocks, snow blowing one storm and pushing snow with my bucket for a couple storms.
Is 15 gallons of fuel use about right for an HST machine?
Seems like a lot to me. No visible fuel leaks anywhere. Air filter is clean and machine was serviced right after I bought it.
/ ck20 fuel use #2
My CK25 didn't start getting good on fuel until about 400 hours. I ran it for about 10 hours and only used about 5 gallons of fuel last weekend. Snowblowing, though, probably is like mowing, and that's usually when you have maximum fuel usage.
/ ck20 fuel use #3
Last summer I dug post holes and moved dirt for 8 hrs and I think I only used 5 gals. 15 sounds high to me, but I am not an expert and do not keep very accurate measurements on fuel.
/ ck20 fuel use #4
That does seem high but depends on your rpms. With my CK30hst, running around 23-2400rpms, I'll use a gallon/hour. In the higher teens, less than a gal/hr.
/ ck20 fuel use #5
That does seem high but depends on your rpms...
More to the point, it depends on how much power you draw, particularly from the PTO. I can do loader work all day and use very little fuel. But running a 6 ft mower (high RPM and some torque) for even an hour or two moves the gauge visibly.
/ ck20 fuel use #6
I've been concerned about 20 litres in about 5 hrs in my CK30 hst. That's 5 gallons, so I'd think 15, no matter what you're running is an issue.
/ ck20 fuel use #7
Definitely sounds high, what rpms do you typically run?
I know I can snowblow my driveway (3-5 hours on the hour meter) on about half to three quarters tank running at 2800 rpms.
/ ck20 fuel use
I dont usually run at high rpm. Try to keep it as low as possible. I wonder if that's why the prior owner sold it. I will have to keep a better eye out for leaks or a bad injector. Doesn't smoke though and has plenty of power.
/ ck20 fuel use #9
I have the CK-20S and I know I can burn through a lot of fuel when snowblowing. Was it heavy wet snow? How much of the eight hours was for snow blowing?
Jon
/ ck20 fuel use
Jon
Maybe 3 hours tops. Yes it was heavy and wet. More just moving wood than any other job.
2015 DODGE MINI VAN (A63290)
2015 DODGE MINI...
2023 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2023 Peterbilt 567...
2016 FORD E450 SHUTTLE BUS (A67148)
2016 FORD E450...
JOHN DEERE 7810 TRACTOR (A64278)
JOHN DEERE 7810...
UNUSED SDLANCH 14' BI-PARTING WROUGHT IRON GATE (A65055)
UNUSED SDLANCH 14'...
CAUTION / STOP SIGNS (A64276)
CAUTION / STOP...
