CK20 Front Axle Fluid Level
   / CK20 Front Axle Fluid Level #1
timberwolf1
Kioti CK20H
I have the shop manual for my CK20 hydrostatic. The manual isn't the clearest or the most detailed I have ever read to say the least. It says to fill the front axle gear oil up to the check plug port. However, the front axle also has a sight glass in the check plug with a dot in the middle. My experience with any sight glass in the past is that they should be filled to the middle mark. The manual says nothing about the sight glass.
Should the front axle be filled with gear oil until it starts to run out of the check plug, or should it be filled to the middle of the sight glass in the check plug?
Thank you.
   / CK20 Front Axle Fluid Level #2
I'd fill it and use the sight glass just for reference that there's oil in it.
   / CK20 Front Axle Fluid Level #3
I have always filled till oil just starts to come out!
2023 CATERPILLAR 279D3 SKID STEER (A51242)
2023 CATERPILLAR...
2021 John Deere 333G Two-Speed Hi Flow Compact Track Loader Skid Steer (A50322)
2021 John Deere...
E-Z Trail Head Cart (A50514)
E-Z Trail Head...
2017 Caterpillar 326FL Hydraulic Excavator (A50322)
2017 Caterpillar...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A52128)
Hay Van FL-95 Bale...
2007 HYDRO-AX 764 MULCHING MACHINE (A51242)
2007 HYDRO-AX 764...
