Loader CK series loader control. Has anyone modified it?
   / CK series loader control. Has anyone modified it? #1
pickeringchris
It might just be me because I am a big horse but I find the loader joystick makes it near impossible to mount or dismount from the right side. This is the side that is easier for me to use when getting the tractor out of the garage. Has anyone modified the joystick to get it a little closer to the seat? Via bending, or cutting and welding etc.
Cheers
   / CK series loader control. Has anyone modified it? #2
Cheers
How interesting, one thing I like about the CK series over the DK series is the fact the joystick is farther from the seat.. I have hit the DK joystick with my thigh several times (especially while in reverse and looking backward). And remembered how the CK joystick is better designed so as not to do that. Now you want to change that.!:) Maybe we ought to just swap joysticks:D.. I have learned to "not do that" on my DK, but I have done it several times in the past, one time I dumped about 100 lbs of cement powder on the gravel , (its still there).. I am sure you could modify it if you wanted to. I though about cutting mine and welding in a section to move it to the right.. I just never did it, and don't really feel the need now.
James K0UA
Now that the gardening season is over I'm just thinking of jobs to do. :).
No way I'm taking that valve out. If anything, ill cut and weld while on the tractor :)
Now I'm wishing I picked up a couple welding blankets the last time I was at harbor freight. :)
They are double the price (at least) in Canada.
I just got some Jeep side mirrors on eBay. They will be a nice addition too. :)
   / CK series loader control. Has anyone modified it? #4
Yeah I looked at the procedure to remove it, and wasn't really too eager either..
   / CK series loader control. Has anyone modified it? #5
Getting just the joystick lever out is not a big problem if you can get the bottom of the boot loose. Lift it up loosen the jam nut and unscrew lever from the pivot base.
This is and extra joystick I have. Plans I have for it, a straight lever might work better so if anyone wants to trade PM me.
   / CK series loader control. Has anyone modified it? #6
heres a simple solution to getting off on the right side and safely backing up. Add a bar by fastening it to an existing bolt between your knee and the joy stick. I nearly took my head off backing up with a lift of 2x4's and not realizing my knee was raising the fel. Looked up just in time!!ck35 017.jpg
   / CK series loader control. Has anyone modified it? #7
Hey Delgra...black Gorillia tape matched the seat much better...ask me how I know?:laughing: Never get in the seat with a 8" screw driver in your back pocket :cool:
   / CK series loader control. Has anyone modified it? #8
Tractor Guys don't miss a thing!
1980 Gleaner F2 with heads (A55315)
1980 Gleaner F2...
2016 Freightliner Bucket Truck (A55973)
2016 Freightliner...
2012 International 4300 Reefer Truck (A56435)
2012 International...
2003 Big Tex 10PI...
AUCTION STARTS HERE @ 9AM (A52709)
AUCTION STARTS...
Yard Machines Tiller (A55973)
Yard Machines...
