CK 3510 HST DISC SIZE
/ CK 3510 HST DISC SIZE #1
ironhayden86
Moscow, PA
JOHN DEERE MODEL M
IM LOOKING INTO BUYING A NEW CK3510 HST AND IM WONDERING IF IT WILL BE ABLE TO PULL A JOHN DEERE KBA 2820 DISC. ITS A 20" DISC DIAMETER 28 TOTAL BLADES AND ITS 8'9" IN WIDTH. THE FRONT BLADES ARE NOTCHED BLADES AND THE BACK ARE SMOOTH.THIS IS ALSO A TOW BEHIND MODEL AND IT ALSO HAS THE TRANSPORT WHEELS.
Does anyone have any experience with using a row behind disc in this size tractor.?
/ CK 3510 HST DISC SIZE #3
Kioti CK3510
2015 - CK10 Series
Compact Utility tractor
Production:
Manufacturer: Kioti (a part of Daedong)
Kioti CK3510 Engine:
Daedong 1.8L 3-cyl diesel
Kioti CK3510 Power:
Engine (gross): 34.9 hp [26.0 kW]
Gear PTO (claimed): 30.8 hp [23.0 kW]
Hydro PTO (claimed): 29.7 hp [22.1 kW]
Capacity:
Fuel: 9 gal [34.1 L]
3-Point Hitch:
Rear Type: I
Control: position control
Rear lift (at 24"/610mm): 1631 lbs [739 kg]
Power Take-off (PTO):
Rear PTO: live
Clutch: dry disc
Rear RPM: 540 (1.375)
Dimensions & Tires:
Wheelbase: 65.7 inches [166 cm]
Length: 120.9 inches [307 cm]
Width: 55.1 inches [139 cm]
Height (ROPS): 99.2 inches [251 cm]
Height (cab): 91.7 inches [232 cm]
Ground clearance: 13.4 inches [34 cm]
Front tread: 44.6 inches [113 cm]
Rear tread: 51.3 inches [130 cm]
Weight: 2679 to 3307 pounds
Mechanical:
Chassis: 4x4 MFWD 4WD
Differential lock: mechanical rear
Steering: power
Brakes: wet disc
Hydraulics:
Type: open center
Valves: 2*
Total flow: 11.7 gpm [44.3 lpm]
/ CK 3510 HST DISC SIZE #4
(If most of Deere Disc Harrow weight is carried on the transport wheels a CK3510 will be able to pull it but penetration depth will be limited to 3" or so, then tractor will stall out.
CK3510 is a too light in weight and underpowered to make full use of this Disc. Disc is almost twice the width of tractor. (55"/105")
A towed Disc does not transfer implement weight to the tractor, the way in which a Three Point Hitch mounted Tandem Disc Harrow does. Tractor traction is less. Draft force retarding tractor is greater because towed discs are not supported by the tractor, only the transport wheels.
