3-Point Hitch CK 30 with mower locked in lift position?
   / CK 30 with mower locked in lift position? #1
ulflyer
lexington nc
CK 30H
With winter upon us I won't be mowing any more till spring. Will it cause any damage if I keep the finish mower locked in the full lift position? I prefer this if possible in order to keep it off the ground moisture, even tho its parked under a carport.
   / CK 30 with mower locked in lift position? #2
Its really not the safest or best practice to leave the 3pt raised with the tractor parked. More than likely will leak down over time if you do anyway. I would use jack stands or large wood blocks to set it on. Just find some that are just fit under it when raised up, then lower the mower on them to take the pressure off the system. No worries of someone or something hitting the lever and lowering the mower.
John Deere 5055E (A53317)
John Deere 5055E...
PAINT ROOM EXHAUST FAN (A54757)
PAINT ROOM EXHAUST...
3 WHEEL ELECTRIC GOLF CART (A55745)
3 WHEEL ELECTRIC...
2010 John Deere TX Gator 4x4 Utility Cart (A55973)
2010 John Deere TX...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A51692)
2007 Ford E-450...
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
