3-Point Hitch CK 30 with mower locked in lift position?
   / CK 30 with mower locked in lift position? #1
ulflyer
Bronze Member
lexington nc
CK 30H
With winter upon us I won't be mowing any more till spring. Will it cause any damage if I keep the finish mower locked in the full lift position? I prefer this if possible in order to keep it off the ground moisture, even tho its parked under a carport.
   / CK 30 with mower locked in lift position? #2
Its really not the safest or best practice to leave the 3pt raised with the tractor parked. More than likely will leak down over time if you do anyway. I would use jack stands or large wood blocks to set it on. Just find some that are just fit under it when raised up, then lower the mower on them to take the pressure off the system. No worries of someone or something hitting the lever and lowering the mower.
Ford 1710 Tractor (AS IS) (A50774)
Ford 1710 Tractor...
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
2013 International Day Cab Semi (A50120)
2013 International...
2022 BUCKEYE BMH CAR HAULER TRAILER (A52141)
2022 BUCKEYE BMH...
Pickup Truck Bed (A51691)
Pickup Truck Bed...
2015 Cadillac Escalade ESV Platinum AWD SUV (A50324)
2015 Cadillac...
