CK 30 ROLL BAR
   / CK 30 ROLL BAR #1
JDL538
California Ky.
CK 30
I love my CK30 I wish I would have bought it 10 years ago. I have one big complant though the roll bar is to high, it could easily be 6 in. lower.
I hit tree's barn doors and in the woods it is down right dangerous, I can't believe it couldn't be 6 in. lower. Has anyone dropped there's down or does anyone else have this problem.
   / CK 30 ROLL BAR #2
They are high. I just watch out for the limbs and will lower it when it needs to go into a building. I guess they use one roll bar for several tractors. I have never measured to see if during a roll over how much clearance your head would have when the tractor would be resting on the hood and roll bar.
   / CK 30 ROLL BAR #3
I had my ROPS cut 11inch when the tractor was new, that way i don't have to lower the rops to get the tractor in the garage. :D
   / CK 30 ROLL BAR #4
I cut those 8 inches out of the bottom of my rollbar, added the reinforcement to the bottom of the modified rollbar that was part of the removed section, redrilled and reinstalled. Works much better now around and under the Apple trees. (CK20HST) Fred
   / CK 30 ROLL BAR #5
I think I will replace mine with one made from soft rubber that way when I hit something with it it will just spring out of the way and snap back up.:laughing:
   / CK 30 ROLL BAR #6
Be sure to put that little squeeky valve in them so you will know when you roll over. :thumbsup:
   / CK 30 ROLL BAR #8
An earlier post about this said that the ROPS are required by some sort of regulation to be X inches higher than the highest point on the tractor. With the BH seat on, the rops is the right height, but alas, it's too high for the regular seat and guys like us hit barn doors etc.
I'd love to cut mine down just 6 inches but I don't have the welding skill.
   / CK 30 ROLL BAR #10
I believe they are designed to prevent the tractor from rolling all the way over. They are made long to act as an outrigger in the event that you do flop it on it's side. But if you think you know more than the designers........:confused3:
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
2022 CASE 580 SUPER N BACKHOE (A51246)
2022 CASE 580...
Caterpillar 430D 4x4 Extendahoe Backhoe Loader (A51691)
Caterpillar 430D...
2014 KENWORTH T680 (A52472)
2014 KENWORTH T680...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2018 FREIGHTLINER...
