CK 30 hay baling???
Status
Not open for further replies.
   / CK 30 hay baling??? #1
ahoude
Yale Michigan
nothing yet
I posted this on the general ag. board also but wanted to post it here also as most on this forum seem pretty knowlagable about the capabilities of the Kioti line. I think I am pretty set on getting a CK30 with gears. I have 17 acres thet I am going to maintain with this tractor (when I finish my house and actually buy a tractor), and think I want to put in about 5-6 acres of crop. 1-2 acres of pumpkins and/or gourds to sell at a roadside stand, and about 4 acres of hay. I'm pretty sure a CK30 and disk, plant, and mow 4 acres of hay, but can it pull and operate a small square baler??? I dont mind the slow pace I would have to operate it at, but would like to know if its possible or would I beat the machine up too much?? Any comments would be appriciated.
   / CK 30 hay baling??? #2
This question gets asked quite a bit. It's not just the hp of the tractor. It's also the weight of the tractor. Too light a tractor, hilly ground, slippery ground and you have an unsafe situation. Also, you're going to have some expenses in equipment and 4 acres isn't a lot of hay.
   / CK 30 hay baling??? #3
Andy:
30 horsepower is plenty for a square bailer and 4 acres but you still have to mow it, rake it, if it gets rained on, ted it and re-rake it again. For 4 acres, I'd have a local farmer fit it for you, then seed it either by drill or broadcast seeder and pull a drag like a section of chain link fence over it to set the seed. 30 horse won't even come close to running a disc mower, but a rear mounted sickle will work. Side delivery rakes are relatively cheap to come by used, but a rotary like a Kuhn takes little power to run and does a better job.
Don't even think of a round bailer, the tractor is too small. Your only consideration safety wise is pulling a sizeable hay rack behind the bailer. The loaded hay rack and bailer can easily outweigh the tractor and make for some white knuckle rides if you are on hilly ground.
I do quite a bit of custom work on smaller plots and charge the Michigan custom rate.
I am thinking of the hay more for a little suplemental feed for a few head of cattle my brother-in-law and I keep talking about with a some for winter deer feed and possibly selling whatever is left. I was hoping a CK30 is enough for a small square baler and most of what I have read seems to indicate it is on the bottom of enough. Someone else also mentioned weight of the tractor being a factor and that seems to be good with Kioti's being heavy. I think I would leave the bales on the ground and get some help loading them on a trailer with my truck rather than pull that much with a tractor. Thanks for the replys.
   / CK 30 hay baling??? #5
Another route to go would be a used tractor. You can pick up a nice used tractor that would handle all of those tasks for under 7K. It won't be 4x4 though. I have to agree though, 4 acres is not alot of hay.
   / CK 30 hay baling??? #6
My question is there reason you need a compact? There are some reasonably priced utility tractors out that might fit the bill.
   / CK 30 hay baling??? #7
Status
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
UNUSED JCT 2 PRONG BALE SPEAR (A58376)
UNUSED JCT 2 PRONG...
UNUSED GRASSROOTS IMPLEMENT 4' BOX BLADE (A58375)
UNUSED GRASSROOTS...
15 35ft. Commercial Black Metal Light Poles (A56858)
15 35ft...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
