CK 30 engine stop solenoid fuse
   / CK 30 engine stop solenoid fuse #1
Ajcracker
Kioti CK 30
I bought a 2008 CK 30 new and from the first there was a clicking and the glow plug light would flash rapidly then gradually slow and finally the light would stay on till the plugs got hot, then the light would go off and then it would start. I knew this was not normal as I previously owned a CK 25, but I got used to the clicking and the wait. However this week it was colder than normal and it would not stop clicking and heat the plugs. Today I replaced the glow plug solenoid and no more clicking. The light came on and then went off, starter turned the engine over but it did not start. Checked the fuses and the 25 amp engine stop fuse was burned out. Put a new fuse in and still no start, checked the new fuse and it was fried. I assume that the engine stop solenoid is bad.
THE FIX
I unplugged the fuel solenoid and moved the shutoff lever forward and the engine still would not start. After I removed the solenoid from the engine and put in a new fuse it fired up. I then carefully avoided the fan pulled the lever to the rear and shut down the engine.
   / CK 30 engine stop solenoid fuse #2
AJ,
Hope that you were careful to remove the white guide sleeve when you removed the solenoid. If not, the guide sleeve will fall into the engine case. The white guide sleeve also has a nipple on the end of it that completes the rack movement to shutdown. Without the sleeve, the solenoid won't shut the engine off.
Michiganiron, thanks for the info; the dealer failed to mention the sleeve when he told me to pull the solenoid. I took a light and mirror down to the shed just now and the sleeve is still in position. It looks like the manual shutoff arm is in the way of pulling the sleeve out. What do I need to do?
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2011 GMC Acadia SLE SUV (A50324)
2011 GMC Acadia...
2018 PETERBILT 579 DAY CAB (A51222)
2018 PETERBILT 579...
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
John Deere 6410 Loader Tractor (A50514)
John Deere 6410...
2015 VOLVO VNL SINGLE AXLE DAY CAB (A51222)
2015 VOLVO VNL...
