CK 30 4 wheel drive
   / CK 30 4 wheel drive #1
VFI540
I am the only one that that a hard time getting my CK 30 into 4 wheel drive. I have had times when I needed it now and the only way to get it in is use my foot or go look for help.
VFI 540
   / CK 30 4 wheel drive #2
VFI 540
Mine was a little stiff at first. The more I used the tractor the easier it was to engage the 4 wheel drive. Now it usually goes in the first try. If not, I just bump the HST pedal a smidge and it will slide right in. If it's really hard to engage, try lifting the front wheels off the ground (if you have a FEL).
Don
   / CK 30 4 wheel drive #3
VFI540:
Welcome to TBN :)! TBDonnelly has good suggestions. Jay
   / CK 30 4 wheel drive #4
As you are attempting to engage 4wd, turn your (steering) front wheel back and forth.
   / CK 30 4 wheel drive #5
Mine works easy by hand now after I got under there and sprayed the linkage with lube.
RING 3 STARTS HERE @ 9:30 AM (A51248)
RING 3 STARTS HERE...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
2004 Sterling Tack Truck (A52384)
2004 Sterling Tack...
47 ft. Portable Transfer Dock (A53117)
47 ft. Portable...
