ck 27 need wiring diagram
/ ck 27 need wiring diagram #1
calfal
lake charles,la.
kubota l275 power king 14/24 kioti ck27
i have a ck 27,, when i start this tractor, i notice the rear tail light is on but the switch is off. if any one has a diagram i sure would aprreciate it.. thanks in advance..
/ ck 27 need wiring diagram #2
On mine the rear light comes on when you start the tractor as well - it goes off when you release the parking brake....
/ ck 27 need wiring diagram #3
Yep, I'd start with the brake light switch. Make sure that the parking brake is off, and that the brake light switch isn't stuck on. Oh, and it sounds like you have a brake light bulb burnt out too. Keep us posted what you find, Dutchy
hey thanks for the quick replys so soon.. i have the manual but it never mentioned these options will check it out further.. thanks again
i should have posted sooner but.... it was the brake lights coming on when i start my tractor... why is the return spring not pulling up the brake pedal..also my brake light holder has prongs that do not exist i have to order a new brake light housing,, also light bulbs from kioti are very expensive when a regular 1157or1156 bulb will do.. thanks again
