CK 20s Tach Not Working
   / CK 20s Tach Not Working #1
gkm
Shepherdstown
Bocat CT335 HST Cab
Hey all,
I had my wiring harness replaced yesterday and all along thought the issue w/ dash and tail lights not working when in headlight switch was in the highbeam selection, that the switch was bad. After watching the tech replace the harness, I still had the same dash/tail light issue and suggested replacing the switch. Of course after replacement, the dash/tail light issue was rectified.
I really didn't pay attention the ensure the tach was working, but it's not. Please help me in narrowing down the problem. I surmise that either the dash connectors are hooked up in the wrong slot or there's a loose connection somewhere.
Any help would be greatly appreciated.
Regards,
Greg
Checked every single connection and found nothing loose or questionable. Kind of perplexed at this time!
   / CK 20s Tach Not Working #3
I would ask the folks who replaced the harness, why your tach does not work now.
I intend to, but was hoping to fix before then. It was replaced on 9/26.
   / CK 20s Tach Not Working #5
The tachometer fior the CK20S is controlled from an alternator signal. Make sure The yellow wire at the back of the alternator is plugged in.
Thanks! I'll check.
Tandem Axle Silage Cart (A50774)
Tandem Axle Silage...
John Deere MX5 3pt 60" Rotary Mower (A50774)
John Deere MX5 3pt...
2020 Kia Sportage LX SUV (A50324)
2020 Kia Sportage...
2018 CATERPILLAR 336FL EXCAVATOR (A52141)
2018 CATERPILLAR...
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
2018 John Deere 331G Compact Track Loader Skid Steer (A50322)
2018 John Deere...
