CK 20s Tach Not Working
   / CK 20s Tach Not Working #1
gkm
Shepherdstown
Bocat CT335 HST Cab
Hey all,
I had my wiring harness replaced yesterday and all along thought the issue w/ dash and tail lights not working when in headlight switch was in the highbeam selection, that the switch was bad. After watching the tech replace the harness, I still had the same dash/tail light issue and suggested replacing the switch. Of course after replacement, the dash/tail light issue was rectified.
I really didn't pay attention the ensure the tach was working, but it's not. Please help me in narrowing down the problem. I surmise that either the dash connectors are hooked up in the wrong slot or there's a loose connection somewhere.
Any help would be greatly appreciated.
Regards,
Greg
Checked every single connection and found nothing loose or questionable. Kind of perplexed at this time!
   / CK 20s Tach Not Working #3
I would ask the folks who replaced the harness, why your tach does not work now.
I intend to, but was hoping to fix before then. It was replaced on 9/26.
   / CK 20s Tach Not Working #5
The tachometer fior the CK20S is controlled from an alternator signal. Make sure The yellow wire at the back of the alternator is plugged in.
Thanks! I'll check.
2005 Isuzu NPR Venco VC516 Landscape Dump Truck (A50323)
2005 Isuzu NPR...
16ft T/A Flatbed Equipment Trailer (A50323)
16ft T/A Flatbed...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2020 Freightliner M2 106 S/A Dump Truck (A50323)
2020 Freightliner...
2006 Cadillac Escalade AWD SUV (A50324)
2006 Cadillac...
