CK-20 HST Check your plugs!
   / CK-20 HST Check your plugs! #1
toddbiss
Enfield, NH
2011 Kioti CK20hst
I had a leak over the summer from my CK 20 and it turned out to be a plug on left side of the Hydrostatic. There is a hole you can look through under the floorboard and there is a plug that has a spot for large allen tool, 10mm I think. So after snugging it up and keeping an eye on it stopped leaking. Today I parked it and noticed a leak checked the plug and it was dry checked the right side which is much harder to get at and see and sure enough it was loose. Just something to keep an eye on.
   / CK-20 HST Check your plugs! #2
Good info. I wonder if this is only a 2011 deal or if it pertains to only newer models. I will check my 08.
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A56858)
2018 Nissan Titan...
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
1992 CATERPILLAR 14G MOTORGRADER (A52709)
1992 CATERPILLAR...
2006 Utility Trailer MFD. T/A 32FT Dry Van Trailer (A56858)
2006 Utility...
14179 (A55788)
14179 (A55788)
