Cistern Pump
/ Cistern Pump #1
jhendric
Holly Springs, NC
none
Folks, I'd like to use rainwater collected in a large cistern to water my lawn. Do I simply need a sprinkler pump or should I also get a pressure tank/pump combo?
/ Cistern Pump #2
If you intend to setup an automatic system with pressure controls a pressure tank will keep the pump from running constantly while in use.
I use a spring fed cistern as the primary water supply and replaced the Jet pump with a submersible earlier this year for a vast improvement in performance.
/ Cistern Pump #3
If all you're running is the sprinklers, you do not need a pressure tank or a pressure switch and I would recommend not having one. I'd use a centrifugal pump or a jet pump and match the sprinklers to the pressure and volume of the pump.
It would be best if you can get the pressure/volume chart on your pump. But, if not, you can draw an approximation just from the max volume and max pressure it will produce. As long as the pump is a variety of centrifugal, you'll be fine. If you chose a positive displacement like a piston pump, then you have to have other piping in the line as well.
Note: the reason for a centrifugal pump is that you can dead head it without damaging it AS LONG AS it is not overheated. Submersibles typically require water flow for their cooling. Ones sitting on the surface typically use air for cooling.
/ Cistern Pump
Thanks guys, Harbor freight has a combo that was interesting but I'd just as soon have fewer components to break.
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2012 Chevrolet 3500 HD (A64127)
2012 Chevrolet...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
Chery 20'x30'x12' Storage Shelter (A64127)
Chery 20'x30'x12'...
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
Chery 21'x24' Double Carport (A64127)
Chery 21'x24'...
