CIH 385 hyd schematic?
/ CIH 385 hyd schematic? #1
Tx Jim
New Member
Coyote Flats,Tx
JD 4255/Kubota M7040 HDC
Is there a place to view online a CIH 385 hyd oil schematic other than a CIH service manual? I'm trying to help a friend get his hyd's operating.Thanks,Jim
Harry
Neighbor stated he was spreading gravel with FEL and hyd's got very weak. Changed hyd filter & checked oil level which is full but still has weak hyd's. I suggested looking for faulty relief valve.
Thanks,Jim
/ CIH 385 hyd schematic? #4
Not sure if it's just my computer or what, but I can't get any IH parts books to open lately. Though not identical, most IH tractors of that vintage have similar systems. Relief valve should be somewhere in the cover plate they call the MCV. That should cover both the lift and auxiliaries. Is the problem limited to loader response or is the three point also weak? If the three point will lift a load, then the relief is probably not an issue. Is the loader supplied from/through the remotes? Steering and PTO working okay?
Harry
I need to ask tractor owner about your questions.
Thanks,Jim
2018 INTERNATIONAL LT DAY CAB TRUCK TRACTOR (A67147)
2018 INTERNATIONAL...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A64280)
2001...
John Deere 12in Channel Bucket w/ Teeth Excavator Attachment (A64194)
John Deere 12in...
WESTFIELD WR641 - 6" X 41' GRAIN AUGER (A64278)
WESTFIELD WR641 -...
2016 PETERBILT 337 CAB AND CHASSIS (A65643)
2016 PETERBILT 337...
2015 CATERPILLAR 336FL EXCAVATOR (A65053)
2015 CATERPILLAR...
