Chronatron Aluminum Rods
   / Chronatron Aluminum Rods #1
Jw5875
NW Pa.
Kubota L3400
Local repair shop purchased some 510 DC+ aluminum welding rods made by Chronatron.
Do these really work ?
jw5875v
   / Chronatron Aluminum Rods #2
I have a friend that used some on a job on the local airport beacon tower. Couldn't get a tig to it and it was all that was available. It hasn't fallen down and has survived a couple of near misses from tornados. I can't speak for them myself. But he said its like trying to shake water out of a garden hose.
   / Chronatron Aluminum Rods #3
Aluminum Stick is difficult because of the travel speed you need to use. The secret is 500 degree preheat and run the rod at a 90 degree angle to the work. Otherwise it wants to spit aluminum all over. If you have oxy-acet set, Turn on acetylene only and smoke the part with the black smoke. Then turn on the oxygen and start heating the part. When the black goes away, You are at 500 degrees. ( or buy a temp stick ) Aluminum Stick rod makes a nice weld when used in a brazing application too. Use it just like brazing rod on on aluminum.
TMA (A49461)
TMA (A49461)
2021 MACDON C3812 LOT IDENTIFIER 34 (A53084)
2021 MACDON C3812...
RHINO DB150 LOT NUMBER 73 (A53084)
RHINO DB150 LOT...
JOHN DEERE LOT IDENTIFIER 112 (A53084)
JOHN DEERE LOT...
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
