"Chrome hydraulic cylinder rods?
   / "Chrome hydraulic cylinder rods? #1
varmint
Elite Member
Northern Maryland
Kubota B8200, then a Kubota L3130 HST, now a Kubota L3400 HST
Stopped by the John Deere dealership this morning (they handle Stihl products, and I needed some chain files) and I noticed that had a good complement of new tractors out front. Being a Kubota man, I was just a bit curious to see what they looked like... I saw that every hydraulic rod was a dull gray, sort of like titanium- not bright chrome like I would expect. This was the coating, not a cover or protective film. What is this all about, and is it a new "standard"?
   / "Chrome hydraulic cylinder rods? #2
As the article states, bright cosmetic chrome is softer than the induction hardened (gray) chrome.
Interesting- I guess I would hope that Kubota would be induction hardening their rods... Like I said, the JD rods weren't shiny at all- almost a mat gray. Always learning. Thanks for the link.
   / "Chrome hydraulic cylinder rods? #4
I would guess that the cylinder rods have been nitrided.
   / "Chrome hydraulic cylinder rods? #5
it's industrial chrome, it's harder than show chrome. if you're a firearms enthusiasts the ar15 uses it on the original colt contracts. on the bolt, in the barrel. in the impingement assembly of the bolt. it's tuff stuff and holds up well. you have to watch hardening of hydraulic cylinders. they are normally left on the softer side to bend and not shatter for being hard.
   / "Chrome hydraulic cylinder rods? #6
This.
JD has been using these on the loaders for 20+ years. Backhoes and other options still have traditional chrome.
   / "Chrome hydraulic cylinder rods? #7
Cylinder rods for agricultural use are normally induction hardened to a surface depth of 1/16" give or take and then plated with hard chrome for corrosion resistance. The case hardening provides resistance to dents and dings while supporting the hard chrome which normally is hair thin. The core of the rod remains "soft" and will normally bend significantly before breaking.
Nitriding, which is sometimes used in lieu of chrome plating, produces a dark finish on the cylinder rod. I suspect that the process is less expensive than hard chrome.
   / "Chrome hydraulic cylinder rods? #8
Years ago I was at a seminar about hyd rod materials sponsored by Fluid Power Society.
It was an in-depth discussion about nitrited vs industrial hard chrome plated.
Several points were brought up about nitrited rods.
The Nitrite process is cheaper to produce hyd rods but removes the possibility to produce induction hardened product due to the intense heat and cool process of nitriding will anneal the induction hardened rod material. Industrial hard chrome does not effect the preprocessed induction hard surface when plating.
Nitrite manufacturers boast about corrosion protect but the salt spray test they use is not a real world test. Under a salt spray test high pressure salt sprayed the nitrite wins under those conditions but chrome plating in routine use gets its corrosion protection from being retracted into the cylinder to get bathed in oil, the chrome plating under a microscope is porous (the reason they corrode when not in use). CP rods being used routinely will out last nitrite.
Nitrite hyd rods cannot be polished during a repair without losing its outer coating. CP rods can be polished easily with no harm.
Two material tests on steel is tensile and yield strength. Yield strength is exceeded when steel bends under stress and stays bent. Tensile strength is exceeded when it snaps. Nitrided hyd rods have the tension and yield strengths near the same numbers. Chrome plated hyd rods will yield before they snap.
This is a big reason why you don’t see hydraulic rods on cranes, manlifts and bucket trucks with nitrided hyd rods. OEM’s would rather have a hyd rod bend during an overload instead of snapped causing severe personal and property damage. I have personally seen many nitrited rods that snapped, laying them out on a table it’s clear they snapped without a noticeable bend.
We build replacement hyd rods for many different industries in our busy hyd shop and I can say more than 50% of cylinders with nitrited hyd rods need replacement because of corrosion. We always change them back to hard chrome plated material with absolutely no issues.
Years ago one of my employees went to a local farm fair (Deerfield Fair, Deerfield NH) and two large John Deere distributors had machines on display. On one side of the road were all yellow industrial machines (excavators, dozers, backhoes etc). On the other all green JD ag equipment. My guy asked the salesman on the green side “why doesn’t JD use chrome plated hyd rods on the green equipment?”. His response was “Oh, it’s much better”. My guys response, “OK then why are all the rods on the yellow equipment chrome plated?”
   / "Chrome hydraulic cylinder rods? #9
... why are all the rods on the yellow equipment chrome plated?”
I had a JD110 TLB (Construction yellow Sold by both ag and construction dealers at the time.) It had chrome rods. The most similar green ag model did not.
   / "Chrome hydraulic cylinder rods? #10
Very interesting post! I'm wondering about the difference in core strength between the nitrided and hard chrome rods and why the nitrided rods would tend to snap instead of bend. Perhaps some hydrogen embrittlement in the nitriding process?
2014 PJ TRAILER 40' TANDEM AXLE GOOSENECK (A52472)
2014 PJ TRAILER...
JLG MANLIFT (A52472)
1986 Peterbilt 359 Truck, VIN # 1XP9D29X9GD196948 (A51572)
1986 Peterbilt 359...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
Ford Tractor (A50120)
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
