Chopped Volvo fire truck .
   / Chopped Volvo fire truck . #1
Eagleview
Orstraya , Ex convict stock , G'day .
This is a picture from the For Sale magazine of the F717 Volvo fire truck i bought to make another water truck out of . It was a dual cab truck with seating for 6 men . I cut the rear section of the cab off and removed the back cab panel and re-attached it to the front half , which makes it a two seater . I then had to build an all new exhaust gantry and rear cab mounts and shorten the wheelbase . Ive just finished the Galvanised water tank support frame and Gal mudgaurds . I shortened up a Kenworth 104 Fibreglass sunvisor and fitted it to the cab , also a Scania windscreen stoneguard and Nissan UD bumper bar to make the truck look a little more modern . It has 74,000 kilometres (46,000 miles)on the clock and still has the original drive tyres fitted . Even though it is an old truck , (1984) it will do a good job as a water truck . I got it registered yesterday , it took around 4 weeks to complete .
   / Chopped Volvo fire truck . #2
I had to look close it really sorta looks like a ford C600 pumper at first glance that I use to drive.
tom
   / Chopped Volvo fire truck . #3
That's a nice finish product... Good job.
I do remember seeing one of those , yes they do look alike . This truck had a transfer case between the tailshafts that run the pump . They would throw an air switch to disconnect the drive to the wheels which would then run the pump . It only had a small tank that held the foam chemicals which were mixed with the re-pressurised hydrant water . It spent it's whole life in the Southport (Gold Coast) fire shed being pampered . The engine was never cold as it had a heating element in the radiator which was plugged into the mains so they could hop in and go flat out in the small hours without hurting it .
Thanks teg , comments like that mean a lot .
   / Chopped Volvo fire truck . #5
Nice work. I love seeing this kind of stuff.
Chris
   / Chopped Volvo fire truck . #6
Very nice! Do you have pics of any other projects?
Thank you , and now that you ask:). (Also post 357 and on , in "Your towing rigs and trailers" there are a couple more)
This is my other truck that i built . The cabin was rusted out and needed a "little" work . After 6 days of hard work , i hung it from the roof of my shed . I then stupidly decided , instead of using an endless chain to lower it onto the chassis , because i was worried about the chain touching the fresh paint , i would use the loader and lift the chassis up to meet it . Just as i put the pins in the cab hinges , which made it all one part . I noticed with horror that the hydraulics on the loader where creeping down and were threatening to turn the cab and my shed into modern art . I had to then run around the truck and hop into the loader and lift the arms . Then at 100 mph get back out and try and untie the cab straps . But as i did the loader crept down again . This took place 4 times before i got the cab untied :rolleyes:. The picture shows it after i untied it , you can imagine the cab and chassis 3' higher and attached too the shed and the hydraulics going down . It all worked out in the end , had a couple of beers that afternoon .
Thank you also Diamondpilot .
   / Chopped Volvo fire truck . #8
How long is the bed.
Can yiu haul your tractor on it?
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A53472)
John Deere 5090E...
UNUSED LANHONOR UHA-16-3000G UTILITY HITCH ADAPTER (A51248)
UNUSED LANHONOR...
UNUSED WOLVERINE PT-16-01C UNIVERSAL ADAPTER (A51248)
UNUSED WOLVERINE...
2024 JOHN DEERE 461R LOT IDENTIFIER 58 (A53084)
2024 JOHN DEERE...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A53426)
2020 INTERNATIONAL...
JOHM DEERE 1600 WAM LOT IDENTIFIER 113 (A53084)
JOHM DEERE 1600...
