Choosing just one grease..
   / Choosing just one grease.. #1
Hysyde
Eastern Ontario, Canada (South of Ottawa)
Since I just have a single grease gun at home (away from the farm shop) I'm trying to find recommendations on the best all-around grease (type/brand) that I can put to just about anything without too much fear of issues.
Obviously it will be a bit of a compromise, but I don't plan on buying a second grease gun, and swapping tubes is not an effective solution, or one I think I'd even do.
At home, the main consumers of grease are my little Ford 1210 with a FEL and a few attachments that take grease, and my Kubota F2100 mower. Other than that, it's ATVs and snowmobiles, but the snowmobile don't have many zerks on them nowadays. I bought a tube of low-temp Mystic grease years ago, and predictably never used it, as again, swapping tubes isn't a real option.
I have can of aviation moly (was used to grease sliding parts on a 25mm chain gun) that I slather on the odd part that it seems appropriate (i.e. sliding parts) or in the place of anti-sieze when I don't have any on hand.
If I put only one type in my gun, what should it be?
   / Choosing just one grease.. #5
I like it , Any grease is better than none.....
   / Choosing just one grease.. #6
For many many years I used only the Ford, Lincoln, Mercury Valvoline® Moly-Fortified Multi-Purpose Grease. I have NEVER had a wheel bearing fail with this grease. It is also rated for high pressure use and is suitable for pin and joint lubrication in most instances.
https://www.autozone.com/greases-an...rd-multi-purpose-grease-tube-14-1oz/54186_0_0
That said I have gone to multiple grease guns and I keep my DeWalt gun loaded with Amalie Pro Tac+ with 5% Moly Grease for my backhoe pins. The 5% moly is too thick for wheel bearings but stays in the high pressure pins longer and require less frequent greasing.
   / Choosing just one grease.. #7
I run a Dewalt gun with general purpose grease and a Milwaukee with red hi-temp grease for pto shafts and mower spindles
   / Choosing just one grease.. #9
I only buy grease with a extreme pressure EP rating now. That's what was recommended for the backhoe. Good for everything else and costs only a little more. Been buying TSC Traveler Premium.
Toro Workman 3200 Cart (AS IS) (A50774)
Toro Workman 3200...
2017 Ram 4500 Bucket Truck (A52748)
2017 Ram 4500...
2012 Chevrolet Traverse LTZ SUV (A50324)
2012 Chevrolet...
2006 Cat 963C Crawler Loader (RIDE AND DRIVE) (NICE) (A50774)
2006 Cat 963C...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
2009 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2009 Ford F-250...
