Choosing between DK4510 and NX4510 HST
   / Choosing between DK4510 and NX4510 HST #1
trctorfan17
northeast
none
Hi,
I am trying to choose between DK4510 (gear or hydraulic shuttle) and NX4510 HST.
I will be using box blade for grading (ground engagement) and loader to move dirt.
I am very comfortable driving race cars with stick shift as well as sedans with automatic transmission. So, I would have no difficulty driving gear in a tractor...but I never drove a tractor before.
Thank you,
   / Choosing between DK4510 and NX4510 HST #2
Go to the dealers and start test driving, then you will start understanding what's what and how they work.
   / Choosing between DK4510 and NX4510 HST #3
Hi,
For loader and box blade work the HST is going to be a lot more convenient and user-friendly. Gear is fine a few times, but after 50 reverses in 1 hour you'll be tired of it. HST also makes it relatively easy to stop precisely, which is very helpful for loading a truck or backing up to a fence.
The gear tractor is IMHO better than HST when doing large areas at a steady speed - mowing, disking, conventional tillage, etc. It also works well for doing smaller tasks at a constant speed - like rototilling a 1-acre plot at 1 or 2mph.
If you go with gear, I think the $1k extra for hydro-shuttle is worth it. I still use the clutch a lot on my DK, but for loader work (etc.) I have the option of using just the reverser lever, depending what I'm doing and whether a few inches of stopping distance matters.
   / Choosing between DK4510 and NX4510 HST #4
I think the NX is a physically a bigger tractor with higher lift capacity and deluxe features.
Thank you very much Z-Michigan, this is very helpful.
Yes, NX is bigger, taller, and heavier too. I think, with the extra deluxe feature, the NX4510HST is probably worth a 1k more than the DK4510 Hydro shuttle.
   / Choosing between DK4510 and NX4510 HST #7
The NX is physically bigger and more deluxe, but rated capacities are roughly the same as the DKxx10 series.
I think OP's decision is made for him anyway because it seems HST is what he wants.
Z-Michigan,
Thank you for your guidance, you are absolutely right...HST eliminates DK from my list of tractors.
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52748)
2013 Doyle Dry...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A52748)
2003 International...
Polaris Side by Side (A50324)
Polaris Side by...
2003 Ford Excursion 4x4 (MPV), VIN # 1FMSU43PX3EC07978 (A51572)
2003 Ford...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
CONTACT INFO (A53084)
