Choke return spring location Briggs 12F802 1173 01
   / Choke return spring location Briggs 12F802 1173 01 #1
wolfden793
Lyndonville Vermont
Deere LX 266, John Deere Gator TX, Kubota B7500, Takeuchi TB016
Hi Folks!
Thanks for all the recent help and kind feedback on removal of stuck connecting rod screw. Now the same engine has a choke return spring that connects from the choke shaft to? This engine was given to me and the spring was in a box with many other parts. I can see where one end hooks to a small hole at the end of the shaft but don't know where the other end goes. Can't find it in my Briggs service manual. I'm sending along a pic of it hooked to the shaft. Briggs part number is 690354 and engine model is 12F802 1173 01. If someone could send me a pic of it connected, that would be great. Any help appreciated! Engine has been completely rebuilt now except for this snag in the ointment!
   / Choke return spring location Briggs 12F802 1173 01 #2
I think that a little larger view might help.
Richard
Hi Richard,
Thanks very much for your reply. Here are two more pics that are further away from the springs location. Looking forward to hearing your thoughts!
   / Choke return spring location Briggs 12F802 1173 01 #6
Wolf
I believe the other end of that spring would connect to the throttle linkage moved by the throttle cable. It should be trying to pull the throttle butterfly open while governor rod would push it closed.
Isn’t that black arm the choke?
   / Choke return spring location Briggs 12F802 1173 01 #7
Looks like this video may have the same linkage and spring setup as your engine
around the 4 minute mark has a good top view of the springs and linkages
Hi Randy,
Perfect! This is exactly what I needed. Thanks everyone very much for their help and responses!
   / Choke return spring location Briggs 12F802 1173 01 #9
Im dealing with the same issue on my B&S mower engine, and this post was incredibly helpful. I Can't find a diagram of this specific linkage anywhere! Let alone replacement parts, specifically the plastic triangular piece the spring in question attaches to. Were you ever able to locate these items in a parts manual/catalogue?
2012 Ford Focus Sedan (A56859)
2012 Ford Focus...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2019 Ford Transit Connect Cargo Van (A56858)
2019 Ford Transit...
2014 PETERBILT 388 VACUUM TRUCK (A55745)
2014 PETERBILT 388...
2006 APPA TL (A55787)
2009 International 7400 Altec A77-TE93 92ft. Material Handling Bucket Truck (A55973)
2009 International...
