Chisel Plow for a 2955 John Deere?
   / Chisel Plow for a 2955 John Deere? #1
deereguy
Ohio
Have a few of this and that...but I bleed green!
What size chisel plow would a John Deere 2955 (80 HP) tractor pull. Tractor is 2WD, tires aren't loaded and has a few suitcase weights on the front.
   / Chisel Plow for a 2955 John Deere? #2
   / Chisel Plow for a 2955 John Deere? #3
my 50 hp john deere pulls a 9 shank like a knife through butter, but in "new ground" which is TOUGH. I hardly ever have to engage front wheel assist, and only when it is so muddy i should park the tractor anyway. if I were you, get a 11 or 13 shank, you can always remove shanks!!!
   / Chisel Plow for a 2955 John Deere? #4
Big difference in some chisel plows. Big difference in what some people do, or expect from a chisel plow.
2955 was sort of a "mid-framed" tractor from Deere's line. I had a 4250. Just one generation earlier, it was a bit larger and heavier, plus 30 more hp, and with weights and fluid in tires, probably 4000 lbs heavier, PLUS MFWD. I used a 9 shank DMI chisel plow that would just about stop the 4250 in its shadow when dropped below 10" deep. We have lots of clay here.
   / Chisel Plow for a 2955 John Deere? #5
My experience had been similar with the heavier, larger framed chisels. We've pulled an 11 shank (12' wide) with a 120hp tractor and it was a load at times for it some the dry, hard soils we have. Now, I have a little light-duty 7 shank with spring trips that I use with my 8n, but it's an entirely different type of implement weighing less and requiring less hp per shank to use.
So, I still wouldn't go over 9 shanks for your 2955 if you are going to use it as any real primary/deep tillage at any reasonable speed. If it handles it fine then you can simple move a little faster.
Thanks to everyone for their helpful information. Jason
2013 CHEVROLET SILVERADO 2500HD (A50854)
2013 CHEVROLET...
GENERATOR HOUSE POWERED BY TWIN (60 SERIES)  DETROIT 14.0L ENGINES (A50854)
GENERATOR HOUSE...
2011 Ford F-450 Crew Cab Omaha Service Truck (A50323)
2011 Ford F-450...
2016 Ford Escape 4x4 SUV (A50324)
2016 Ford Escape...
2013 JLG 8042 TELEHANDLER (A50854)
2013 JLG 8042...
377811 (A48836)
377811 (A48836)
