Chisel Plow for a 2955 John Deere?
   / Chisel Plow for a 2955 John Deere? #1
deereguy
Ohio
Have a few of this and that...but I bleed green!
What size chisel plow would a John Deere 2955 (80 HP) tractor pull. Tractor is 2WD, tires aren't loaded and has a few suitcase weights on the front.
   / Chisel Plow for a 2955 John Deere? #2
   / Chisel Plow for a 2955 John Deere? #3
my 50 hp john deere pulls a 9 shank like a knife through butter, but in "new ground" which is TOUGH. I hardly ever have to engage front wheel assist, and only when it is so muddy i should park the tractor anyway. if I were you, get a 11 or 13 shank, you can always remove shanks!!!
   / Chisel Plow for a 2955 John Deere? #4
Big difference in some chisel plows. Big difference in what some people do, or expect from a chisel plow.
2955 was sort of a "mid-framed" tractor from Deere's line. I had a 4250. Just one generation earlier, it was a bit larger and heavier, plus 30 more hp, and with weights and fluid in tires, probably 4000 lbs heavier, PLUS MFWD. I used a 9 shank DMI chisel plow that would just about stop the 4250 in its shadow when dropped below 10" deep. We have lots of clay here.
   / Chisel Plow for a 2955 John Deere? #5
My experience had been similar with the heavier, larger framed chisels. We've pulled an 11 shank (12' wide) with a 120hp tractor and it was a load at times for it some the dry, hard soils we have. Now, I have a little light-duty 7 shank with spring trips that I use with my 8n, but it's an entirely different type of implement weighing less and requiring less hp per shank to use.
So, I still wouldn't go over 9 shanks for your 2955 if you are going to use it as any real primary/deep tillage at any reasonable speed. If it handles it fine then you can simple move a little faster.
Thanks to everyone for their helpful information. Jason
2016 VOLVO VN SERIES SLEEPER (A50854)
2016 VOLVO VN...
NEW HOLLAND TS6.130 TRACTOR (A51406)
NEW HOLLAND...
American Sanders EZ-8 Electric Floor Sander (A49461)
American Sanders...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
2019 JOHN DEERE 317G SKID STEER (A51242)
2019 JOHN DEERE...
