Chipper/Shredder and Newspaper
/ Chipper/Shredder and Newspaper #1
hunterridgefarm
Western NC
Kubota L3130DT, Kubota L185DT, JD LX277
I bought a Troy Built Chipper/Shredder at an auction a few years back and use it to chip up prunings and small limbs for mulch or compost.
I try to recycle old newspapers and magazines and thought about trying to run the newspapers through the Chipper and putting them in the compost pile.
Anyone ever tried this? Do you think it will work?
/ Chipper/Shredder and Newspaper #2
I don't know about a chipper but I do know a rolled up newspaper will bring a 7-24 snowblower to a belt snapping stop.
/ Chipper/Shredder and Newspaper #3
I don't think it will work at all. Chipper/shreaders have a hard time with leaves because they are so thin and flexible. The chipper wants to knock small chips off of a big limb and the shreader wants to take small limbs and brush and rip them apart. With paper, it would just curve around the blades and jam because the paper is too flexible to shear. It's kind of like using a loose pair of scissors to try and cut paper.
I have a chipper-shreader that can do leaves, but it has to have a special grate that is much bigger than the one it normally uses for wood. It takes repeated recycling through the shreader to really do much to the leaves. On the other hand, my rotary mower with a mulching blade does a great job of turning huge piles of leaves into tiny 1/4" pieces. I love it!:D
/ Chipper/Shredder and Newspaper #4
I don't see why it wouldn't work. As long as you ran a few pages at a time along with some branches or limbs.
JIm,
Thats kinda what I was thinking, paper would just curve around the blades.
But also thought I could drop a section or two of paper in with some small limbs like BillyP stated.
I still must give it a try just to see if it works:eek: .
/ Chipper/Shredder and Newspaper #7
If your goal is to use newspaper for mulch or compost I suggest a different way that works well. After I plant and before I mulch I put down newspaper about 5 pages thick. It will stop weed growth for up to 3 seasons. Put it down, mulch over it and do the same thing 3 years later. The newspaper is broken down by then and has enriched the soil.
/ Chipper/Shredder and Newspaper #8
Make sure the newspaper was printed with Soy ink otherwise it might be a chemical you might not want to eat if this is a veggie garden.
Later,
Dan
2021 International HX620 Quint Dump (A62613)
2021 International...
Wolverine Brush Cutter BC-13-72W Skid Steer Mount  (A62679)
Wolverine Brush...
3 Bottom Plow (A65640)
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2021 VOLVO VNL860  6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
2022 EZ-GO ELITE...
