Chipper hookup to tractor hydraulics
   / Chipper hookup to tractor hydraulics #1
Caco4x4
Santiago, Chile
Jinma 404 (2023)
Hi folks newbie here again.
Just finished assembling my new WC-8 Chipper and I need to know how to hookup the hydraulics to the tractor.
This is what I have;
   / Chipper hookup to tractor hydraulics #3
Is your tractor equipped with all female ends?
Seems so
   / Chipper hookup to tractor hydraulics #5
So you're going to need something with male QA ends and threads on the other end. What a frustrating problem in a world of convenience.
I'm browsing Parkers catalog, but it's amateur hour.
   / Chipper hookup to tractor hydraulics #6
Hopefully there are some identification on the tractors quick connect. If the dealership doesn't know the worst thing you'd have to do is unthread one of those and carry it in to a hydraulic supply and ask for the mating male side.... x4.
There are good references online but the male ends show the required profile and the FM end will require x-ray vision.
The above link may be helpful.
Unless you have a little bit of knowledge of commonly used threads, I'd carry along on of the chippers hoses to have them identified, many such domestic ag/hydraulic these might typically be common male pipe thread. Being female and I think I see a chamfered seat inside and there's a small world of choices it might be from Bpp, Bsp, JIC.
The more of your parts that you can drag into the hose shop and ID, the fewer trips you'll have to make AND the fewer adapters and joints (leaks) you'll ultimately have.👍
The Jinma 404 tractor came with 4 extra male QA male connectors that are too big for any on the tractor.
My 4in1 bucket has male connectors.
Are these what I need for the chipper?
   / Chipper hookup to tractor hydraulics #8
That or something like it. Try it to see if fits (and "clicks in") to each other. You'll probably need 2 wrenches to remove a rear FM coupler and keep everything clean.
   / Chipper hookup to tractor hydraulics #9
Most quick connectors have a model and brand stamped on them somewheres, thats the first place to start.
What does ISOB PF-3/8 mean?
2018 INTERNATIONAL DURASTAR 4300 REEFER BOX TRUCK (A58214)
2018 INTERNATIONAL...
1751 (A58375)
1751 (A58375)
2004 DITCH WITCH 3700 RIDE ON TRENCHER (A52709)
2004 DITCH WITCH...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58216)
RIPPER ATTACHMENT...
103 (A56857)
103 (A56857)
2231 (A58376)
2231 (A58376)
