CalG
Super Member
- Joined
- Sep 29, 2011
- Messages
- 5,105
- Location
- vermont
- Tractor
- Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200
The wear bar on the MacKissic chipper shredder is worn out.
I layed out a couple of replacements on a sheet of 1/4 " plate, but then got to wondering if there would be something better.
Thinking of adding a hard edge suggests a few options.
Weld on a length of grouser hard bar and grind back to square.
Build up the old edge with 7000 series filler rod.
Build up the edge with hard facing rod
'Could make the piece from some alternate material than the 1/4 " plate stock (if avaialble from my local steel supply.)
The thing is only about 6 inches long, by an inch and a a half wide. It needs about 3/8ths inch added on. So i'm not inclined to "special order" anything exotic. The present one has probably 100 hours on it, and it's at the end of the adjustment, with still about 1/8 inch gap to the knives. (spec is 1/16"-3/16") I would set it closer if it weren't worn ;-)
Ideas?
Ideas?
