Chimney Repair
   / Chimney Repair #11
A chimney is designed to draw the smoke and gases produced by a fire up and safely out of your home. This is extremely important since some of these gases are dangerous. One of the most dangerous is carbon monoxide which in large enough doses can kill. This is why it is so important for you to make sure that any needed chimney repair is done correctly in order to keep you, your family and your home safe.
Reads like a spammer. What does all that have to do with putting siding on the outside of a chimney?
3 posts about nothing.
   / Chimney Repair #12
Double check the instructions. I believe they'll want 2" of gap between the shingles and the bottom piece of siding. When done properly you should see the step flashing. The cement board does absorb water and over time it will swell. They space it off the roof to try and get it away from the water on the shingles.
UNUSED LANDHONOR LHR-SP50 HYD SHOP PRESS (A54757)
UNUSED LANDHONOR...
2012 Chevrolet Traverse LTZ SUV (A53424)
2012 Chevrolet...
Kubota LA1055 (A53314)
2006 Isuzu NPR-HD Landscape Dump Truck (A53422)
2006 Isuzu NPR-HD...
2023 KAUFMAN MINI V CAR HAULER TRAILER (A54607)
2023 KAUFMAN MINI...
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
