Chevy 1500 series suspension work question.
   / Chevy 1500 series suspension work question. #1
Cactus
Guys,
In a previous thread I mentioned I was working on my Chevy 1500 series work truck suspension....replacing a leaf spring that had broken. I went to the local wrecking yard and got the springs I needed. My cousin is helping me (really I am helping him) I told him that I wanted a little bit of extra height on the rear and he recommended I buy some lift blocks,he said I would get new U bolts with the lift blocks which I need as well.
My question's are how high is too high ?
Before I start making phone calls etc,would Advance Auto/Auto Zone/ or Napa be able to get these ? My guess is yes...
Thanks
Cactus
   / Chevy 1500 series suspension work question. #2
<font color="blue"> I told him that I wanted a little bit of extra height on the rear </font>
Why? Just curious.
BTW, adding another another leaf into each spring pack will add height as well as additional load capacity.
   / Chevy 1500 series suspension work question. #3
You may want to check out this forum:
Link
</font><font color="blue" class="small">( <font color="blue"> Why? Just curious. </font> )</font>
My trailer jack has been dragging in the gravel in the driveway. Just a little added clearance for when I have my trailer hooked up.
   / Chevy 1500 series suspension work question. #5
is the trailer heavier than what the truck is rated to tow?
if not don't do blocks, just add a leaf or two.
or even better take it to a spring shop and see what they think.
   / Chevy 1500 series suspension work question. #6
add leafs not blocks. blocks will raise the truck no doubt, but do absolutely nothing else other than possibly ruining the drive shaft U joints because of the higher angle.. At least with added leafs, you get true weight increase and some lift besides..
   / Chevy 1500 series suspension work question. #7
Cactus, I'm assuming this truck is 2wd and is stock. With the trailer on the truck is sitting lower in the rear than desired.
Could it be possible that the trailer is loaded with too much tongue weight? If not I would definately not use rear lift blocks to compensate for too much tongue weight or weak suspension.
With out seeing it for myself, the one thing I could reccomend at this point is coil over shocks which will aid in load carrying capacity approximately 300lbs which might be enough to keep you trailer jack out of the dirt and aids in handling as well. Adding a leaf is also another way to beef up your suspension but IMO is a little extreme for one particular circumstance that you encounter. Rear shocks are so much easier to do /forums/images/graemlins/wink.gif, thats where I would start... /forums/images/graemlins/cool.gif
Thanks guys...I really appreciate your feedback.... /forums/images/graemlins/cool.gif
   / Chevy 1500 series suspension work question. #9
<font color="blue"> Adding a leaf is also another way to beef up your suspension but IMO is a little extreme for one particular circumstance that you encounter. </font>
But since he's already getting a broken leaf spring replaced, it makes sense to simply add in another leaf now.
   / Chevy 1500 series suspension work question. #10
MikePA, Well you have a point there, I think I missed the broken spring part this morning /forums/images/graemlins/crazy.gif But I still think coil over shocks would be the better solution ride wise (more forgiving ) until loaded .
2019 CATERPILLAR 299D2 XHP SKID STEER (A52705)
2019 CATERPILLAR...
Black Galvanized Steel Fencing Kit (A53424)
Black Galvanized...
48 Inch Grapple Root Bucket (A55218)
48 Inch Grapple...
2006 Kobelco SK210LC Hydraulic Excavator (A52377)
2006 Kobelco...
2005 FORD F350 XLT SUPER DUTY SERVICE TRUCK (A51406)
2005 FORD F350 XLT...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
