chevron's Recommendation on Coolant (BX)
/ chevron's Recommendation on Coolant (BX) #1
tomnky
Platinum Member
Berea,Kentucky
Kubota BX2200
chevron\'s Recommendation on Coolant (BX)
I e-mailed Chevron and asked what They had for a BX.
Attached is what they sent me.
I gave them the specs quoted in the manual (J1034,J814C),
They told me this meets J1034 and that J814C is only a publication.
<font color="red"> Thank you for your inquiry. ATSM D 3306 is a standard for Automotive light duty antifreeze, J 1034 is an SAE recommended practice for engine coolant concentrate, ethylene glycol based for use in light duty trucks or automobiles. J 814 is a report and not a specification. For a diesel engine I would recommend the Delo ELC it does meet the specifications of J 1034.
Glenn
</font>
Thought some might be interested in this tidbit. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
  • 688653-Delo ELC.pdf
/ chevron's Recommendation on Coolant (BX) #2
Re: chevron\'s Recommendation on Coolant (BX)
I have been using this coolant now for several years with great results. I use it in the premix 50/50. I use it in a fleet of 25 trucks and 50 reefer trailers. If you are switching from the old green to this you want to do a real good job of flushing out all the old green antifreeze as they do not mix. I have also switched over all of my personal equipment to this coolant.
In my fleet I have noticed a reduced repairs in the cooling system and feel that the biggest reason is the change in coolant, my mechanic's agree too.
I guess that is enough rambling on!!!!!
/ chevron's Recommendation on Coolant (BX) #3
ASTM D 4985 is what you care about with a wiesel. It is phosphates and silicate free, which is good.
What about these?
GM 1899
GM 1825 including ASTM D 1384 (Glassware Corrosion), ASTM D 2570 (Simulated Service)
ASTM D 2809 (Cavitations Erosion - Aluminum Pumps) ASTM D 4340 (Hot Surface Aluminum Corrosion).
For flushing I would do this. You need to flush the old coolant out since it will have silicates in there and you can leave them in there for years. You will have green goo everywhere. Plus you can't mix ELC and normal coolant together.
Go to your local grocery store and buy "White Distilled Vinegar" and mix that 50/50 with some distilled water.
Fill the system with the 50/50 mix, run the bike until warm, let cool, drain and then run clear water through to wash out the vinegar.
It's the same idea as cleaning your coffee maker.
The vinegar is acidic enough to remove any scale or impurities, but not so harsh that it will harm your delicate seals and gaskets.
/ chevron's Recommendation on Coolant (BX) #4
</font><font color="blue" class="small">( ...........................Go to your local grocery store and buy "White Distilled Vinegar" and mix that 50/50 with some distilled water.
The vinegar is acidic enough to remove any scale or impurities, but not so harsh that it will harm your delicate seals and gaskets. )</font>
If your tractor is a bike, then my tractor must be a quad since I have 4 wheels as opposed to your two.... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Komatsu D39PX-23 Dozer (A64047)
Komatsu D39PX-23...
2015 WESTERN STAR  4900 SB (A63569)
2015 WESTERN STAR...
2006 John Deere 325 Skid Steer (A63116)
2006 John Deere...
MOBILE HOUSE SKID (A63569)
MOBILE HOUSE SKID...
2006 CHEVROLET EXPRESS 4X2 SERVICE BOX TRUCK (A59911)
2006 CHEVROLET...
2018 CATERPILLAR 326FL EXCAVATOR (A64279)
2018 CATERPILLAR...
