Chevron Synthetic THF vs. Amsoil Hydraulic Oil?
Status
Not open for further replies.
   / Chevron Synthetic THF vs. Amsoil Hydraulic Oil? #1
CenturyGreg
Western Pennsylvania
Century 2028 C-50HL FEL
I am planning to use either Amsoil 5W30 synthetic hydraulic oil or Chevron All-Weather Synthetic THF in my new tractor. Locally they are about the same price (Chevron $62.50/5gal. : Amsoil $65.00/5gal.) so price doesn't really matter. Are either of these hydraulic oils going to be better than the other or is it a draw?
   / Chevron Synthetic THF vs. Amsoil Hydraulic Oil? #2
It's a draw. I'd go with what is readily available and that would be the Chevron.
   / Chevron Synthetic THF vs. Amsoil Hydraulic Oil? #3
Look for some test sheets etc. I would and do base my oils on perfomance and not where I can buy them. I can buy Fords for example all over the place, but it does not mean it is the best in that class either.
Another example, I can buy a no name dvd or tv at Walmart but I would not buy it just since I can buy it close to home. They is much more to buying a product they that.
   / Chevron Synthetic THF vs. Amsoil Hydraulic Oil? #4
<font color="blue"> I am planning to use either Amsoil 5W30 synthetic hydraulic oil </font>
I was not aware that Amsoil made a muti-weight hydraulic fluid. Multi-weight engine oil, yes, but not hydraulic fluid.
   / Chevron Synthetic THF vs. Amsoil Hydraulic Oil? #5
Yes, there hyd fluid has a 5w-30 SAE rating.
   / Chevron Synthetic THF vs. Amsoil Hydraulic Oil? #6
<font color="blue">Yes, there hyd fluid has a 5w-30 SAE rating. </font>
This must be the change they made recently. The ATH I have indicates SAE 30.
   / Chevron Synthetic THF vs. Amsoil Hydraulic Oil? #8
I think it is on their website, Mike.
   / Chevron Synthetic THF vs. Amsoil Hydraulic Oil? #9
When I did the 50 hour service on my CK20, I used Amsoil ATH. I ordered a 5 gallon bucket and 2 quarts because I was expecting the change to use the entire 5 gallons and wanted the quarts for top offs and such if needed... or if I got a leak and needed to replenish after fixing the leak.
The 5 gallon bucket I received was 5w-30, but the two quarts were straight 30 weight. They were both ATH from Amsoil.
The other thread that was running about ATH not meeting the Kubota spec.. was it run on ATH straight 30 weight or on the multi-viscosity version and which is right (or are they both right)... argh
   / Chevron Synthetic THF vs. Amsoil Hydraulic Oil? #10
<font color="blue"> I think it is on their website, Mike. </font>
Thanks, I found it on their web site. My point was that the bottles of ATH I have (bought last summer) indicate SAE 30.
Status
2007 PETERBILT 335 FUEL & LUBE TRUCK (A51406)
2007 PETERBILT 335...
NEW HOLLAND TS6.120 TRACTOR (A51406)
NEW HOLLAND...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
2011 CIRCLE M 32 FOOT GOOSENECK (A53843)
2011 CIRCLE M 32...
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
