ChiefBodie
- Joined
- May 25, 2018
- Messages
- 128
- Tractor
- Ventrac 4500Y
Caught the field on fire and had to extinguish a fire. Wound up using three (out of four) chemical extinguishers and was surprised by how limited they are. These are residential grade, and they barely put the fire out along with help from some water jugs. Then I learned it is a bit of a hassle to take them in for recharge at a dealer, along with a small cost. Close to throw away and buy new.
The responding fire personnel recommended a 2.5 gal stainless steel pressurized water fire extinguisher. Apparently you can put water in, then pump it up using an air compressor or bicycle pump. Then it sits there waiting to be used, if ever. At 2.5 gallons, they are higher capacity, but for Class A fire only (trash, debris, etc.) I presume this is perfectly fine for putting out a fire in a brush pile or pasture.
Does anyone have experience with these? Sounds better than the residential grade models.
2 1/2 Gallon Stored Pressure Water Fire Extinguisher - Amerex 240 - Fire Extinguishers - Home, Business Vehicle Fire Safety
